Would you please help me (Solving Diodes Problem)
eng.hussein
eng.hussein
@enghussein-i1SU2y Oct 22, 2024
What's up everyone
I am a fresh man studying Communication Engineering we had a problem in electronic class which is below it is about diode series and parallel configuration I did not find similar in Boylestad Book Solve it ASAP .
[​IMG]
Regards
  • pratap singh, upendra
    @pratap-singh-6xlmve May 24, 2012
    Assuming that you know the difference between a forward biased diode and a reverse biased diode.
    in order to solve such problems there are two approaches
    • ideal case
    • non-ideal case
    for ideal case analysis, see if the diode is forward biased or reverse biased. If it is forward biased, then replace it by a short wire; in the other case assume it to be an open circuit and proceed like any electrical circuit problem.
    however in non-ideal case, replace the forward biased diodes with short wires and add a battery of value equal to the pinch off voltage(nearly 0.7 volts for germanium and 1.1 volts for silicon) in such a way that on moving in direction of current positive plate of the battery is incurred first. Reverse biased diodes are simply replaced by an open circuit.
    it looks like non-ideal approach has to be followed
    Do inform me if you get the correct results on solving the transformed circuit.
  • eng.hussein
    eng.hussein
    @enghussein-i1SU2y May 24, 2012
    You are right bro it is a non-ideal case and we should determine the current by using Kirchoff voltage law for each loop but my major concerned is about the diodes when it will be converted to a voltage source and applying VKL are they will be summed with the regular Voltage source like any electrical circuit if they are in the same direction and subtracted if they are in opposite ?
    By the way I had my final exam couple days a go and I did well 👍
    Thanks respectfully
    @pratap-singh-6xlmve May 25, 2012
    eng.hussein
    Thanks respectfully
    but I did give you the way to connect the diode equivalent voltage sources; just use it to find out the solution
