wL communication
Janaa karti
@janaa-karti-HrEwL0 • Oct 26, 2024
Guys I need to transmit a signal at the range of 0 to 10 meters (aprox) .which signal can I use???? RF or IR..
If RF .then how can I reduce d distance range to RF ???
    @ramani-VR4O43 • Dec 12, 2015
    Why not a laser diode beam? IR if the beam should not be seen. Optical if this is not a requirement. Can be modulated for security.
  • Janaa karti
    @janaa-karti-HrEwL0 • Dec 12, 2015
    I want to do it in low cost and I wanna transmit the signal in 360°
    @ramani-VR4O43 • Dec 13, 2015
    Do you mean a spherical wave front like a radio transmission? Then RF is probably best. Or a spherical LED lamp modulated by the signal being transmitted.. The receiver may need to have a telescopic collector to eliminate external interference.
  • [Prototype]
    @prototype-G9Gn5k • Dec 13, 2015
    The RF transmitters generally operate on a voltage range. The lesser is the voltage, the lesser is the range.
  • Janaa karti
    @janaa-karti-HrEwL0 • Dec 13, 2015
    The 433 MHZ RF transmitter has the approx range of 100 meters ... How can I reduce its range to 0 to 10 meters????
  • [Prototype]
    Janaa kartiThe 433 MHZ RF transmitter has the approx range of 100 meters ... How can I reduce its range to 0 to 10 meters????
    Difficult to precisely confine the range. Run it on a lowest permissible voltage. That's the most you can do.
  • Janaa karti
    I m not expecting the exact range.... I jus want approx 10 meters ..
    Thank u .. And I'll try ur idea
