Wireless Video Tx and Rx Project
bhavin_20feb
@bhavin-20feb-FssHHC โ€ข Oct 25, 2024
Hello friends..... i got an project idea, in which i have to transmit the AV signals within the the range of 25-30 feet region. The Tx module has AV input from digital camera. And at the other side I want to receive the output on my PC (and mobile also, if possible). I have to transmit and receive the data wireless, and the size of the antenna should be very small, like the antenna of our wireless router... Can u people please help me ?? What should I do to for this ?? How to make Tx and Rx for this ?? Please give ur suggestions..... Thank u very much... ๐Ÿ˜ ๐Ÿ˜€
    @abrakadabra • Apr 28, 2011
    Thread moved to appropriate section.
  • Hari Prasath
    @hari-GB3Lia • May 5, 2011
    bhavin_20febHello friends..... i got an project idea, in which i have to transmit the AV signals within the the range of 25-30 feet region. The Tx module has AV input from digital camera. And at the other side I want to receive the output on my PC (and mobile also, if possible). I have to transmit and receive the data wireless, and the size of the antenna should be very small, like the antenna of our wireless router... Can u people please help me ?? What should I do to for this ?? How to make Tx and Rx for this ?? Please give ur suggestions..... Thank u very much... ๐Ÿ˜ ๐Ÿ˜€
    Buddy don't think small, think big๐Ÿ˜›..
    The concept which you are saying is what we are using in our daily security cameras and cctv.
    The existing system uses RF frequency for transmission n reception,which is similar to the cable tv system but without wires..
    Try something new yaar.. surely we will help you..
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • May 5, 2011
    Check out this basic introduction on how to build projects using Zigbee. I guess your application would require Zigbee protocol so that the wireless capacity may be effective upto 50m.
    Another great intro tutorial to start with...
    ZigBee is an established set of specifications for wireless personal area networking (WPAN), i.e. digital radio connections between computers and related devices.
    WPAN Low Rate or ZigBee provides specifications for devices that have low data rates, consume very low power and are thus characterized by long battery life. ZigBee makes possible completely networked homes where all devices are able to communicate and be controlled by a single unit.
    Read More: #-Link-Snipped-#
    @harshad-ukH5ww • May 5, 2011
    Zigbee works on 2.4GHz-2.7GHz and this is the reason why it has not much range but if we go with 433MHz RF Signal then we can get the range more than 500 meter. ๐Ÿ˜€
