Wireless moving robot
parsi.praneeth@g
@parsipraneeth-at-g-85421f Oct 26, 2024
hi all,
i am new to embedded systems designing...
i am trying to move the robot in all directions using ir rays...
i am ready with the receiver part i.e of ir sensor ...
but i am lagging with the knowledge of transmitter coding and how to pass the signals with that code i.e 0's,1's ..
can any one help me out from this problem..
also help me what to be studied to know about the wireless technologies i.e how to code and pass the signals..
  • nitin.rawat
    @nitinrawat-y0tzFj Dec 8, 2010
    try this one.just remember to make some calculations about ic555 yourself.
  • limestone7000
    @limestone7000-AV88z8 Feb 4, 2011
    dude, u can control it with the supply of IR transmitter,
    when u wanna send '1', then switch on the supply, when u wanna send '0' then u cut off the supply. Isn't this the simplest form of control?
  • nitin.rawat
    @nitinrawat-y0tzFj Feb 5, 2011
    dude let me clear this to you.if you are making it just an on off switch then its like a 1 bit encoder and decoder process....you cannot control 4 actions from this.i.e.forward backward right turn and left turn...and if you want to control you would have to make four sensors of different frequencies and that would obviously be very costly.
  • Morecott
    @morecott-qm97GX Mar 16, 2011
    nitin.rawat#-Link-Snipped-#
    Dude the link is corrupted or banned by the admin of the forum..
    Because I was trying to open it but it was not working fine...
    @thebigk Mar 17, 2011
    MorecottDude the link is corrupted or banned by the admin of the forum..
    Nope. It's working fine. Check again: #-Link-Snipped-#
  • nitin.rawat
    @nitinrawat-y0tzFj Mar 19, 2011
    sorry if the link is broken but i cant help it if the admin is blocking the access from this site. just do one thing go on google n type multyremotes the first result would be this site n if you further need any assistance just give me your email id and i will send you the circuit diagram on your id.
  • nitin.rawat
    @nitinrawat-y0tzFj Mar 20, 2011
    just tell me first basically what type of codes do you want to study in wireless.infrared of rf codes..
