Wireless Charging
KuldeepR
@kuldeepr-1IELog • Oct 26, 2024
Project Abstract / Summary :
WIRELESS CHARGING
Inductive charging (also known as "wireless charging") uses an <a href="https://en.wikipedia.org/wiki/Electromagnetic_field" target="_blank" rel="nofollow noopener noreferrer">Electromagnetic Field</a> to transfer energy between two objects. This is usually done with a charging station. Energy is sent through an <a href="https://en.wikipedia.org/wiki/Inductive_coupling" target="_blank" rel="nofollow noopener noreferrer">Inductive Coupling</a> to an electrical device, which can then use that energy to charge batteries or run the device.
Induction chargers typically use an induction coil to create an alternating electromagnetic field from within a charging base station, and a second induction coil in the portable device takes power from the electromagnetic field and converts it back into electrical current to charge the battery. The two induction coils in proximity combine to form an electrical <a href="https://en.wikipedia.org/wiki/Transformer" target="_blank" rel="nofollow noopener noreferrer">Transformer - Wikipedia</a>. Greater distances between sender and receiver coils can be achieved when the inductive charging system uses <a href="https://en.wikipedia.org/wiki/Resonant_inductive_coupling" target="_blank" rel="nofollow noopener noreferrer">Resonant Inductive Coupling</a>. Recent improvements to this resonant system include using a movable transmission coil i.e. mounted on an elevating platform or arm, and the use of advanced materials for the receiver coil made of <a href="https://en.wikipedia.org/wiki/Silver" target="_blank" rel="nofollow noopener noreferrer">Silver</a> plated <a href="https://en.wikipedia.org/wiki/Copper" target="_blank" rel="nofollow noopener noreferrer">Copper</a> or sometimes <a href="https://en.wikipedia.org/wiki/Aluminium" target="_blank" rel="nofollow noopener noreferrer">Aluminium</a> to minimize weight and decrease <a href="https://en.wikipedia.org/wiki/Resistance" target="_blank" rel="nofollow noopener noreferrer">Resistance</a> due to the <a href="https://en.wikipedia.org/wiki/Skin_effect" target="_blank" rel="nofollow noopener noreferrer">Skin Effect</a>.
  • Protected connections – no <a href="https://en.wikipedia.org/wiki/Corrosion" target="_blank" rel="nofollow noopener noreferrer">Corrosion</a> when the electronics are all enclosed, away from water or oxygen in the atmosphere.
  • Safer for medical implants – for embedded medical devices, allows recharging/powering through the skin rather than having wires penetrate the skin, which would increase the risk of infection.
  • Durability – Without the need to constantly plug and unplug the device, there is significantly less wear and tear on the socket of the device and the attaching cable.
  • No e-waste
  • Non -radiative energy transfer
Disadvantages :
  • Lower efficiency, waste heat – The main disadvantages of inductive charging are its lower efficiency and increased resistive heating in comparison to direct contact. Implementations using lower frequencies or older drive technologies charge more slowly and generate heat within most portable electronic.
  • Slower charging – due to the lower efficiency, devices can take longer to charge when supplied power is the same amount.
  • More expensive – Inductive charging also requires drive electronics and coils in both device and charger, increasing the complexity and cost of manufacturing.
Newer approaches reduce transfer losses through the use of ultra thin coils, higher frequencies, and optimized drive electronics. This results in more efficient and compact chargers and receivers, facilitating their integration into mobile devices or batteries with minimal changes required.<a href="https://en.wikipedia.org/wiki/Inductive_charging#cite_note-Pogue_Pre.2C_NYTimes-3" target="_blank" rel="nofollow noopener noreferrer">Inductive Charging Cite Note Pogue Pre.2C Nytimes 3</a><a href="https://en.wikipedia.org/wiki/Inductive_charging#cite_note-4" target="_blank" rel="nofollow noopener noreferrer">Inductive Charging Cite Note 4</a> These technologies provide charging times comparable to wired approaches, and they are rapidly finding their way into mobile devices.
For example, the <a href="https://en.wikipedia.org/wiki/Magne_Charge" target="_blank" rel="nofollow noopener noreferrer">Magne Charge</a> vehicle recharger system employs high-frequency induction to deliver high power at an efficiency of 86% (6.6 kW power delivery from a 7.68 kW power draw).
Our Thinking About Disadvantage :
[​IMG]
1: Induction charging cannot work on distant objects.
2: If we put a coin on the induction charger then the coin get start heating this can be dangerous.
3: Can’t use mobile for longer time at the time of charging.
Solution :
[​IMG]
[​IMG]
1: We can use Magnetic Resoance in Induction charging to get the more efficiency of the Induction.
2: Overheating is not possible (Our assumption 98%).
3: Mobile can be use at the time of charging.
Why did you choose to work on this project topic : Because this the most advance and realistic project and technology.wireless charging had already change the view of charging in technology world,if our assumption works then this will be the golden opportunity for us to contribute in this Modern Technology
Project Category : CS / IT / Networking
Institute/College Name: Vaish College of Engineering
City: Rohtak
State: Haryana
