Windows Live Messenger 2011 Problem
eng.yousef
@engyousef-E019K6 โ€ข Oct 22, 2024
how are you everybody ?
let's go into the subject
I have a very strange problem with windows live Messenger 2011
It was working with me perfectly , suddenly it gave me a white blank on it
so I can't sign in or sign out or doing anything
the stranger thing is " this is about one email account " but when I sign in from and other MSN account it works perfectly !!!!!!!
I know this is strange but this is really happen
I tried these points :
* re-install the program
* delete the program from registry and programs files
* delete MSN plus and IM sweet
* I even deleted firefox ๐Ÿ˜ญ
but it doesn't work
Now I am using MSN 2009 ๐Ÿ˜” and it works good with that two account But I still need 2011
Thank you for helping me
@_@
  • Reya
    @reya-SMihdC • Sep 9, 2011
    Did you had this problem in IE9?
  • eng.yousef
    @engyousef-E019K6 • Sep 9, 2011
    No , I didn't have this problem in IE9 before , and I don't have it now
    The problem is Just I can't sign in window live messenger 2011 with a specific email
    But other mails work so good !!!
    thanks for help ๐Ÿ˜€
  • Reya
    @reya-SMihdC • Sep 10, 2011
    If you are using AVG antivirus,uncheck MSN Protection from Online Sheild under Instant Messaging and save it.
    (Or)
    1. Uninstall WLM using the WLM Installer.
    2. Download the Windows Installer Cleanup Utility.
    3. Install the cleanup utility, run it, and remove the WLM Installer Information via the cleanup utility.
    4. Re-download the installer from the WLM website.
    (or)Clear all your registers using Uniblue registry clearer.And you can login to your account.
    5. Re-install WLM.
  • eng.yousef
    @engyousef-E019K6 • Sep 10, 2011
    Thank you Reya for being with me
    I don't have AVG antivirus
    I did all that 5 points
    still not working but there is something changed
    It gave me this message
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: msnmsgr.exe
    Application Version: 15.4.3538.513
    Application Timestamp: 4dcdb2b3
    Fault Module Name: DWrite.dll
    Fault Module Version: 6.1.7601.17514
    Fault Module Timestamp: 4ce7b817
    Exception Code: c0000005
    Exception Offset: 00073938
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 1025
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    thanks again
  • warrenjsanchez23
    @warrenjsanchez23-yOfOQ0 • Sep 12, 2011
    Hi eng.,
    The Windows Installer Cleanup Utility has been expired by the Microsoft but user can still obtained it or same type of software from many 3rd-party download sites.However it is known that it may cause potential damage to Office 2007 installation - that is the reason MS has discontinued Windows Installer Cleanup Utility. But you can still get the programs that work much better then Windows Installer Cleanup Utility and donรขย€ย™t conflict with any program in Windows. You can download this software from the link provided below and fix your problems with that. It is most updated software with many additional features.#-Link-Snipped-#
  • eng.yousef
    @engyousef-E019K6 • Sep 21, 2011
    So Sorry for being late, I was in a job trip
    I installed windows installer cleanup utility , I scanned , found some problems with IE9 then I reinstalled , windows installer cleanup not correct errors just scanned
    So please would you mind to help me find another program
    Yeah , I have tune up utilities 2011 , I checked the error and correct it . but nothing changed
    this video maybe will explain much clearly for the problem
    [video=youtube;pTaNXZBQkk4]https://www.youtube.com/watch?v=pTaNXZBQkk4[/video]
  • eng.yousef
    @engyousef-E019K6 • Sep 23, 2011
    I have installed " Registry Mechanic " program for fix registry errors, but nothing change
    I repaired windows, but nothing change.
  • eng.yousef
    @engyousef-E019K6 • Sep 29, 2011
    Please ,, help me .. I still have the problem
  • Reya
    @reya-SMihdC • Sep 29, 2011
    Follow the first seven steps given in this link.If you still face the problem,let me know!
  • Reya
    If you still face the problem,try to reset your password.
    You will find the link here to reset your password.what is the error *********(number) you get when it stops working?
  • Reya
    which antivirus are you using?
  • eng.yousef
    @engyousef-E019K6 • Oct 1, 2011
    ReyaFollow the first seven steps given in this link.If you still face the problem,let me know!
    I followed all seven steps with more than 30 restarts for computer
    But I still force the same problem
  • eng.yousef
    Reyawhich antivirus are you using?
    as you can see in the video I use kaspersky 2011 antivirus
    " Don't worry I know about AVG problems "
    I don't think that problems is due to pass word because I can access to my messenger from anywhere else.
    Thank you very much for helping me
