@guttu-Udy454 • Dec 31, 2009
Size of the file is it's actual size. As you know disks are made up of different file systems. FAT32, NTFS etc. and files are saved in clusters. Each file system has it's cluster size. FAT32 has 8KB and NTFS has 4KB. Consider a file of 3KB. When it is saved on FAT32, it will acquire 8KB as it's the minimum size of cluster. On NTFS it will acquire 4KB.
Also when you allow file compression for NTFS filesytem, Size of file on disk may turn less than the actual file size. You can check the size of WINDOWS folder which is compressed by default. -
@gauravbhorkar-Pf9kZD • Dec 31, 2009
Thanks for the information Guttu.
@silverscorpion-iJKtdQ • Jan 1, 2010
But I have another question then..
As per the above explanation, the difference between the size of the file
and the size on disc should be small, essentially equal to the cluster size of
the file system at its maximum. But that's not the case.
In my PC, in some cases of large AVI files, size of the file is around 1GB but size on disc is about 1.1GB. That's 100 mb more, right? Why is there such a huge difference? -
@manish-r2Hoep • Jan 1, 2010
silverscorpionBut I have another question then..
In my PC, in some cases of large AVI files, size of the file is around 1GB but size on disc is about 1.1GB. That's 100 mb more, right? Why is there such a huge difference?I think that are some pointers that points to these files...There is no doubt a file will consume space as per their requirement..on disks
and extra space will be occupied by these pointers...
CORRECT me if i am wrong -
@guttu-Udy454 • Jan 1, 2010
In my PC, in some cases of large AVI files, size of the file is around 1GB but size on disc is about 1.1GB. That's 100 mb more, right? Why is there such a huge difference?Can you provide a screenshot?
goyal420I think that are some pointers that points to these files...There is no doubt a file will consume space as per their requirement..on disks
CORRECT me if i am wrongpointers are stored in MFT which is not counted in filesize.
