@saandeep-sreerambatla-hWHU1M • Sep 14, 2010
If you say n-channel it is made up of Silicon.
Silicon has high power handling capacity. So probably that is one of the reason. -
@shreyasm89-jGobVm • Sep 15, 2010
I think it has more to do with the channel width between the source & drain in a n-channel MOSFET than a p-channel MOSFET.
@prakashneo-jcyN0Q • Sep 19, 2010
Hi,
NMOS - the carriers are electrons and so higher velocity and hence much faster.
PMOS - Holes --> heavier than electrons --> Slower speed.
For same speed, the size of PMOS should be much more than nmos ==> Density reduction
All logics can be implemented just with the use of NMOS.
Just for clarification - both nmos and pmos are made of Silicon substrate, its only that the dopants vary.!!
Cheers,
Prakash
