do You Know why Java is called Programmers Language?0
Member • Jan 16, 2010
Re: JAVA -Programmer's Language
Java is called a programming language because it was originally developed by James Gosling at Sun Microsystems and released in 1995 as a core component of Sun Microsystems' Java platform. The language derives much of its syntax from C and C++ but has a simpler object model and fewer low-level facilities. Java applications are typically compiled to bytecode (class file) that can run on any Java Virtual Machine (JVM) regardless of computer architecture. Java is general-purpose, concurrent, class-based, and object-oriented, and is specifically designed to have as few implementation dependencies as possible. It is intended to let application developers "write once, run anywhere".
"Java language" redirects here. For the Indonesian spoken language, see Javanese language.
Not to be confused with JavaScript.
Are you sure? This action cannot be undone. -
Is the Question same ?
why JAVA is called a Programmer's Language?
why JAVA is called a Programming Language?Are you sure? This action cannot be undone. -
am sorry. i misunderstood the question. i will find and tell you.Are you sure? This action cannot be undone. -
Nice question. But i think so it only called as programming language.Neha Kochhardo You Know why Java is called Programmers Language?Are you sure? This action cannot be undone. -
Member • Jan 17, 2010
Question is Regarding Why it is Programmer's Language ?It is not concerning to that Programming LanaguageAre you sure? This action cannot be undone. -
because it is specifically meant for programmer's only.No doubt it is quite similar to
Basic English language but it is for ease of understanding and also English is known by
everyone.
also it is obvious that java cannot be used for communication ie why it is commonly
called programmer's LanguageAre you sure? This action cannot be undone. -
Administrator • Jan 17, 2010
I don't know who called it so. I simply searched on Google to find out whether JAVA is really called programmer's language and there's no evidence that its called so.
See: <a href="https://www.google.com/search?hl=en&source=hp&q=%22programmers+language%22&aq=f&oq=&aqi=" target="_blank" rel="noopener noreferrer">"programmers language" - Google Search</a>Are you sure? This action cannot be undone. -
As far i remember it is popularly known as Internet Language
Never heard of term programmer's language being associated with javaAre you sure? This action cannot be undone. -
Member • Jan 18, 2010
i think you can say this if talking about jsp ie advanced java not for corejavaAre you sure? This action cannot be undone. -
It is related to java applets.goyal420i think you can say this if talking about jsp ie advanced java not for corejavaAre you sure? This action cannot be undone.
