CrazyEngineers Archive
Old, but evergreen and popular discussions on CrazyEngineers, presented to you in read-only mode.
@Naman Agarwal • 04 Oct, 2013 • 1 like
why do ceiling fan rotates in anticlockwise direction and table fan in clockwise direction?
@Kaustubh Katdare • 04 Oct, 2013
https://www.crazyengineers.com/threads/direction-of-rotating-of-blades-in-the-fan.52736/naman2511why do ceiling fan rotates in anticlockwise direction and table fan in clockwise direction?
@yogi.bharadwaj • 05 Oct, 2013
because the ceiling fan is on ceiling but table fan can be treated like a motor.the ceiling fan is on roof and it should blow air in downward direction and table fan is to blow bacword air to forward.we can also say that the air mainly in natures direction and its clockwise and if the ceiling fan is also clockwise then it can't be able to suck air on roof and blow it downward.but a table fan has a large area to suck the air and blow it outwards.i think thats the reason if i am wrong pls correct me.
@Sarathkumar Chandrasekaran • 05 Oct, 2013
A better observation,
I have a doubt= If the blades were turned in alternate way, can we get good air with fan rotating clockwise?
for your an other reason occurs that is the ceiling fan is the rotor which has the winding and rotates it self of in other words it is the winding rotor which rotates.but in table fan the rotor is rotated by the external field so in other words if we said in case of winded casing the it is also in anticlockwise .i think it is sufficient to describe it my friend.if i am wrong pls correct me friends.SarathKumar ChandrasekaranA better observation,
@Anoop Kumar • 05 Oct, 2013
In my view this is the best answers.pknaveen17Since in ceiling fan the rotating part is stator (Body, the part without armature winding), but in the table fan the rotating part is rotor (the part with armature winding), so both fan's rotating direction is opposite.
Both have same meaning but the way to explain is different.
How if the terminals are interchanged?So that It will rotate in clockwise direction.
Anyone out there with exact answer? Please post it .
@Saandeep Sreerambatla • 05 Oct, 2013
In case of a single phase ac motor which is not designed to reverse the direction it will not make any difference.
In case of Permanent Magnet DC motor, you can change the direction either by changing the connections to field winding or armature winding.
For changing the direction in a single phase ac motor you must find a way to reverse the connections to the field magnet or to the armature or rotor for reversible motors.
and motor with brushes, this will be a big problem to change the terminals.
If you change terminals not all motors reverse the direction of rotation.SarathKumar ChandrasekaranHow if the terminals are interchanged?So that It will rotate in clockwise direction.
@Naman Agarwal • 29 Oct, 2013
We can change the direction of rotation of table fan since it incorporates shaded pole induction motor. If we change the shaded pole from left extreme to right extreme the we can reverse the direction of rotation. But we dont do it because it has became the convention for rotation.
15.7k views
@Ankita Katdare · Aug 13, 2013
Hyundai Motor India Limited, the company that was recently in news for the launch of Hyundai Grand i10 is back at headlines to celebrate its 15th anniversary. With the launch...
3.6k views
@WASEEM R · Apr 21, 2011
hiii guys im mechanical engg N i need some m tech prodn engg seminars plz help me
4.2k views
@The_Small_k · Dec 7, 2011
Hello guy's
Actually i want to start an IT company.I posted this thread to know how to start ?
Well i am good in java.I have developed no of...
7.2k views
@Ankita Katdare · Feb 16, 2015
The official price in India for the Google Nexus 9 tablet 32GB+LTE variant is out in the open. HTC and Google have silently released the tablet in India via Amazon.in...
3.5k views
@Ankita Katdare · Feb 13, 2015
I have searched far and wide on the internet, but I haven't found a solution. I got a documentary from a friend which has hardcoded Chinese subtitles. Now even though...
87.2k views
