  • why do the system files get corrupted often?
    Reya
    Reya
    @reya-SMihdC
    Updated: Oct 4, 2024
    Hi friends Can someone explain me why do the system files get corrupted often??
    One of my system files got corrupted and i was not allowed to go inside.I formatted my system and started using it again!
    After some few days when i logged on i get the same error as one of your system files got corrupted.Why do my system files get corrupted often?
    What should i do to recover from this problem??
  • narayana murthy
    MemberDec 12, 2010
    i think virus may be a problem for that or any of your application may results it to be corrupted as i know try any utilities like glary,tuneup etc....,
  • optimystix
    MemberDec 12, 2010
    praveena211
    probably a case of bad sectors on your hard disk. Get it checked
  • Deepika Bansal
    MemberDec 13, 2010
    one word of advice-->> create system restore point whenever your system is working fine.....that will help you to easily recover your system......
  • narayana murthy
    MemberDec 24, 2010
    but there will be problem with system restore
    if we had made system restore there will be uninstalled files will appear and even they dont run this make much disturbance and loss of memory
    i had faced it when i had restored my system
  • HirenBarbhaya
    MemberDec 24, 2010
    Rather than formatting and re-installing everything.. it is very easy to repair the operating system...
  • Deepika Bansal
    MemberDec 24, 2010
    narayana murthy
    well in that case, we'll be restoring our system in a healthy state........... so i don't think there should be any problem.
    Please tell me your experience in detail so that i can make myself more clear.......😀
  • Deepika Bansal
    MemberDec 24, 2010
    HirenBarbhaya
    but for that we should be knowing the exact problem in our system, isn't it.......??
    PS: I am talking about windows operating system..
  • HirenBarbhaya
    MemberDec 24, 2010
    Deepika Bansal
    Yes but rather than blindly formatting the system... what we can do is.. put the Operating System CD and boot from that... and while installing select Repair option...
    Hopefully that should solve the problem.. if it is related to system files only...
  • narayana murthy
    MemberDec 24, 2010
    @deepika: once i got a problem with my system all the system got of my control
    i tried to solve by restarting but no use
    at the time i had restored to previous safe date
    but i had got the problem because of installing a software that was solved
    later i noticed that a uninstalled program appeared on my programs menu i tried to uninstalled from there but no use
    i searched in control panel and tried to remove but no use then i went to local disk where my os is situated and tried to delete the file but it had showed it cant be deleted
    then i got no other choice and formatted my system after that situation i never restored my system
    anyway i used some utilities like glary,tuneup etc.,glary is free software so i am using it now
    now my system running is good
    this is my experience with system restore
  • shreyasm89
    MemberDec 24, 2010
    @Deepika- Hiren's suggestion is great. Instead of formatting it is best to repair. System files get corrupted due to viruses from the internet. Also you can 'hide' your system folder.
