@harshad-ukH5ww • Aug 27, 2012
T.THINAKARANwhy machine take more starting current?
Bot every Machine taking too much current. Can you give details about the machine?
@prototype-G9Gn5k • Aug 27, 2012
godfatherBot every Machine taking too much current. Can you give details about the machine?
I think by machine he means the motor. Electrical people call them machines...๐
Well, taking the example of an induction motor, when the machine is at rest, both stator & rotor have speed of 0 RPM. As soon as you start it, the stator will produce a field that would be like 1500 RPM while the rotor will be at 0 RPM. Following to Lenz law, the rotor will try to make this difference as low as possible, so it has to jump from 0 to 1500 asap. For this, it'll just draw tremendous current. For this reason, we utilize starters.
Some citations may be needed as I am not very good with these motors but I believe that's the reason. -
@tthinakaran-Ll6Ic2 • Aug 27, 2012
thankyou for given answers
