  • rahul69
    @rahul69-97fAOs • Aug 28, 2013
    pradeep.pawarMost of the ip addresses on a network range in class C which is 192.168.0.0, why class C? why not class B,C,D or E widely used?
    It's because class C network has less number of hosts per network and thus suit the need of smaller organizations.
  • Nayan Goenka
    @nayan-Dhpt4N • Aug 28, 2013
    Class C ip addresses are perfect for a network where there are about 100 clients(rough figure). Class C IP address is thus generalized as default and is used in basic configurations. Apart from this, the number of hosts it supports, there is no other particular reason to justify it.
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Aug 28, 2013
    Widely used? That's a wrong impression. All classes of network addresses are equally "widely used" - the reason they exist. Do some nslookup's and see for yourself.
  • vikaskumar11233
    @vikaskumar11233-J10JeV • Aug 28, 2013
    That's because C class provides large not of net masks as well as subnet masks as much as hosts are available.
  • pradeep.pawar
    @pradeeppawar-RAMDdD • Aug 28, 2013
    Anand TamariyaWidely used? That's a wrong impression. All classes of network addresses are equally "widely used" - the reason they exist. Do some nslookup's and see for yourself.
    Most ips range in C class in to say that.
  • durga ch
    @durga-TpX3gO • Aug 31, 2013
    Its how an IP address was 'read' when they were introduced.
    Class A has 8 network bits and 24 host bits, so the maximum networks what can be formed are (2^8) -2, where as the number of hosts what can be accommodated is (2^24)-2. There are very very few enterprises who can use so many host IPs. hence leading to wastage of Ip addresses, the present class A IP mostly will be subnetted IPs and not a /8. Same is the case with Class B and Class C
    Classes in current age don't mean much (except in few intricate networking concepts), IP addresses currently are allocated as VLSM , based on number of Hosts IPs the company needs
  • pradeep.pawar
    @pradeeppawar-RAMDdD • Sep 1, 2013
    durgaIts how an IP address was 'read' when they were introduced.
    thanks.
