why are oxygen storage tanks kept vertical
hello guys
i found that a liquid oxygen storage tank in an industry is kept vertical and that of lpg is kept horizontal. why is it so??
details
the liquid oxygen from oxygen carriers is fed into a storage tank which is kept vertical (pressure inside it is somewhere around 11 kg/cm2). this liquid oxygen is then fed to a vapouriser from the outlet of the tank which is placed at the bottom of the tank.
conclusions
since the tank is kept vertical it is difficult to carry out maintenance work as the tank is some 10 meters high. also it is difficult to maintain a 10 meter massive structure stand vertically. if the reason is to pump the liquid oxygen through the vapouriser with the pressure head, why cant we use a pump to do the same????
details
conclusions
