which Port identifies battery charger?
kiruthikar
@kiruthikar-l3prTT โ€ข Oct 26, 2024
When I plug in the charger to the mobile, what is the means of communication between the mobile and the battery, i,e, what signal is generated when a charger is plugged in and where is it generated. How does the mobile know that a charger has been plugged in and allows battery charging? How to get control of that point?๐Ÿ˜•
  • reachrkata
    @reachrkata-FOcqhH • Dec 4, 2010
    There is usually a battery management IC which does this. It senses the presence/absence of power and starts charging accordingly.
  • kiruthikar
    @kiruthikar-l3prTT • Dec 4, 2010
    reachrkataThere is usually a battery management IC which does this. It senses the presence/absence of power and starts charging accordingly.
    Is there any means of getting access of that ic using a microcontroller? please help
    @harshad-ukH5ww • Dec 4, 2010
    I think Microcontroller decide that using ADC value of the voltage. Not sure !
  • shreyasm89
    @shreyasm89-jGobVm • Dec 20, 2010
    @godfather- I guess the charger input is DC itself so problem of ADC is solved.
    @kiruthikar- I'm sceptical as to whether that power management IC will be digital.This should solve most of your queries-https://www.siliconfareast.com/power-mgt-ic.htm
  • NDL
    NDL
    @ndl-XpBSAS • Dec 21, 2010
    Not from that field but with my personal experience I would say it may be the same IC. as few days later my mobile got damaged and it was not showing anything not even it was charging. The engineer told me that its IC has been damaged and they will have to replace it.
    @harshad-ukH5ww • Dec 22, 2010
    shreyasm89@godfather- I guess the charger input is DC itself so problem of ADC is solved.
    Yes. ๐Ÿ˜€
