Which object is the most difficult to achieve?
aum225
@aum225-DzlGZF โ€ข Oct 23, 2024
1)execute every statement of a program atleast once
2)execute every branch statement of a program atleast once
3)execute every path of a program atleast once
4)execute every condition of branch of statement of a program atleast once
  • aum225
    @aum225-DzlGZF • Mar 19, 2013
    it may be option C right??
    @thebigk • Mar 19, 2013
    aum225it may be option C right??
    Maybe you should make an attempt to answer it on your own. Why do you think option C is right and why options A,B,D aren't?
  • Thirumeni
    @thirumeni-vhzmBq • Nov 20, 2013
    Its answer is C . Because the preprocessor take more time to excute full Excecution program in header...if it take a certain portion to excecute which programmer used..in preprocessor wont excute every thing..it take only based on need so is answer...other A,B and c are common to use in program...
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Nov 21, 2013
    ThirumeniIts answer is C . Because the preprocessor take more time to excute full Excecution program in header...if it take a certain portion to excecute which programmer used..in preprocessor wont excute every thing..it take only based on need so is answer...other A,B and c are common to use in program...
    This sounds very confusing. For Java, there's no preprocessor. So how does your explanation hold true?
