Which language to use
Pensu
@pensu-8tNeGU โ€ข Oct 26, 2024
Hi ppl,
I am coding a program and in that i have to handle a very large amount of data. It can vary from 1 to 1000000000. I am using "C" and "unsigned long int" data type, but my program hangs every time i try to run it over 1000000. Any suggestions???
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 Jun 26, 2011
    Why don't you try C#.NET 2008 and use BLOB format?
  • Pensu
    @pensu-8tNeGU Jun 26, 2011
    @praveenscience: will try that...thnks..๐Ÿ˜€
    I said C# because, it is kind of Platform Independent. Mono for Linux and Mac... ๐Ÿ˜€ And you can use your own C / C++ Codes to work on it... ๐Ÿ˜€ And, BTW, what is the logic you are trying to implement? I mean, I didn't understand your problem... ๐Ÿ˜”
  • Pensu
    @pensu-8tNeGU Jun 27, 2011
    Basically i have been given a task to find out primes in the range of 1 to 1000000000. So i made the code but my program hangs as soon as i input data greater than 1000000. So i thought may be its the problem with data type.
    @praveenkumar-66Ze92 Jun 27, 2011
    Yeah, first of all data type should be some kinda looong integer... and secondly, C doesn't have that much memory to handle the data... ๐Ÿ˜”
  • Pensu
    Yeah.....its looks like that. And can you please elaborate the part with memory. Whats this memory restriction???
    Dude, C Applications are 16 bit apps, which cannot handle more than 16bit of instruction and data... Whereas C# is a 32 bit application and it can handle much higher data... ๐Ÿ˜€ Got it?
  • Pensu
    Hmm......thanks...๐Ÿ˜€
    You are welcome... ๐Ÿ˜€
  • rubensg
    @rubensg-xq7xaE Jun 27, 2011
    Well, you can pretty much do the same function on C just with a different approach. If you machine has multiple cores, you can program in threads so that you make them run on different processing units concurrently. I think that would be enough to handle the amount of data you are going to feed it.
    In case that would not be enough, C# would be there to do it for you.
    Actually, that doesn't work in C. Since, DOS works only in a single thread model, C too does the same! ๐Ÿ˜”
