@al-otaiby-IfzGz4 • Feb 3, 2012
In spur gears teeth suddenly meet at a line contact across their entire width causing stress and noise. Spur gears make a characteristic whine at high speeds. Whereas spur gears are used for low speed applications and those situations where noise control is not a problem, the use of helical gears is indicated when the application involves high speeds, large power transmission, or where noise abatement is important. The speed is considered to be high when the pitch line velocity exceeds 25 m/s.
You have different types of bevel gears, with straight bevel gears, the abrupt tooth engagement causes noise, especially at high speeds, and impact stress on the teeth which makes them unable to take heavy loads at high speeds without breaking. For these reasons straight bevel gears are generally limited to use at linear speeds less than 1000 feet/min; or, for small gears, under 1000 r.p.m.
So the conclusion is; spur gears are more noisy. -
@viky1147-Ru5Vmg • Feb 6, 2012
Well done -
@suryan-KQwB3P • Feb 9, 2012
N.Gowtham RajHey guys... Which gear is noisy?
Spur or Bevel?
Reason?spur gears bcoz as for the design of the spur gears, when the meshing of the two gears make comtact with each other there,firction is developed an so it makes noisy
@ce-designer-BWq0yl • Feb 10, 2012
The involute form of the spur gear teeth helps reduce the noise as it allows for smooth tranisition between the teeth.
@keerthivasan-hrKQir • Feb 13, 2012
Spur or Bevel?
Reason?"BEVEL GEAR"
The advantage of the spiral tooth over the straight tooth is that they engage more gradually. The contact between the teeth starts at one end of the gear and then spreads across the whole tooth. This results in a less abrupt transfer of force when a new pair of teeth come in to play. With straight bevel gears, the abrupt tooth engagement causes noise, especially at high speeds, and impact stress on the teeth which makes them unable to take heavy loads at high speeds without breaking. For these reasons straight bevel gears are generally limited to use at linear speeds less than 1000 feet/min; or, for small gears, under 1000 r.p.m
Gears made of non โ Metallic materials give noiseless operation at high peripheral speeds. -
rkvasan68"BEVEL GEAR"
"SPUR GEAR"
Spur or Bevel?
Reason?
In spur gears teeth suddenly meet at a line contact across their entire width causing stress and noise. Spur gears make a characteristic whine at high speeds. Whereas spur gears are used for low speed applications and those situations where noise control is not a problem, the use of helical gears is indicated when the application involves high speeds, large power transmission, or where <a href="https://en.wikipedia.org/wiki/Noise_abatement" target="_blank" rel="nofollow noopener noreferrer">Noise Abatement</a> is important. The speed is considered to be high when the pitch line velocity exceeds 25 m/s.
SOURCE-#-Link-Snipped-# -
@ce-designer-BWq0yl • Feb 13, 2012
These are all accurate responses. You should have a clear understanding now Gowtham ๐
@zaveri-5TD6Sk • Apr 21, 2012
spur gears are noisy. this is because the area of contact between the two meshing teeth is more. so thus to reduce this we have helical gears, whose function is the same as that of spur gears, to transfer power between two parallel shafts, but helical gears have teeth inclined at an angle to the axes of the shafts, thus reducing area of contact and reducing noise
