    @thebigk • Dec 26, 2008
    To the best of my knowledge, Ubuntu uses Debian Linux source code. Correct me if I'm wrong.
    Addendum: Take a look here - #-Link-Snipped-#
  • Aashish Joshi
    @aashish-VrevFC • Dec 28, 2008
    The_Big_KTo the best of my knowledge, Ubuntu uses Debian Linux source code. Correct me if I'm wrong.
    Yes, Ubuntu is based on Debian.
    If you need the kernel source code, follow these steps:
    1. Make sure you have the source code repository enabled. To do this, go to System>Administration>Software Sources and check the source code repository. Reload the package information.
    2. Open a terminal window and type
    sudo apt-get install linux-source-2.x.xx
    Replace 2.x.xx with the kernel version. If you don't know what your kernel version is, use the following command:
    uname -r
    The output will be something like this "2.6.27-9-generic"
    In this case you will have to replace 2.x.xx with 2.6.27
    Also look at the following post for more information <a href="https://ubuntuforums.org/showthread.php?t=200634" target="_blank" rel="nofollow noopener noreferrer">Ubuntu Forums</a>
  • zia.sepsis
    @ziasepsis-0NGPzn • Dec 28, 2008
    thanks mates.... this may be help full for me too๐Ÿ˜
  • sauravgoswami
    @sauravgoswami-UAfTlI • Dec 28, 2008
    well i have ubuntu CD, i have to check wheather they have source code in it,if yess,i will get back to you
  • Aashish Joshi
    @aashish-VrevFC • Dec 29, 2008
    I forgot to mention that you have to be connected to the internet to install the source code. Almost all the software that you install through the repositories is downloaded from the internet.
