@reya-SMihdC • Jan 8, 2012
I think this is due to high current in transformer windings which causes the windings to vibrate and thus it produces the sound.
Correct me if i am wrong! -
@thebigk • Jan 8, 2012
I miss my electrical engineering days (and knowledge as well ๐จ) but it could be because of the vibrations of the steel plates used in the core of the windings.
@erh3m4l-IOm6WT • Jan 8, 2012
Biggie thats true shot...!!!
@born-star16-U2z3az • Jan 8, 2012
The_Big_KI miss my electrical engineering days (and knowledge as well ๐จ) but it could be because of the vibrations of the steel plates used in the core of the windings.
Perfect!!!!!!!!!!!!!!
@marwano-31BC7N • Jan 8, 2012
Thank u all guys
@aarthivg-HH344f • Jan 9, 2012
In transformers, the physical reaction force between primary and secondary windings when heavily loaded. If the secondary winding is open-circuited, there will be no current through it, and consequently no magneto-motive force produced by it. However, when the secondary is loaded, the winding generates an mmf, which becomes counteracted by a reflected mmf in the primary winding to prevent core flux levels from changing. These opposing mmf's generated between primary and secondary windings as a result of secondary current produce a repulsive, physical force between the windings which will tend to make them vibrate. Transformer designers have to consider these physical forces in the construction of the winding coils, to ensure there is adequate mechanical support to handle the stresses. Under heavy load conditions, though, these stresses may be great enough to cause audible noise to emanate from the transformer.
