What will happen to charges that flowing i devices once after supply switched off?
pr159260
@pr159260-4NR0Kn โ€ข Oct 26, 2024
hi hello All,
i have a doubt in basis that is what will happen to electrons(current) that flowing in devices once after stopped either that produced by battery or from power supply that we use in house? whether electrons goes back to source or what happens to that charges?
Somebody clear me ๐Ÿ˜ฒ_O
  • pr159260
    @pr159260-4NR0Kn • Feb 23, 2013
    and whether that charges produced by source or that will already in available in devices and equipment.. just the drifting work done by source?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Feb 23, 2013
    Conductors have charges in them the Potential applied Just moves these charges in the desired direction That is what we call current
  • pr159260
    @pr159260-4NR0Kn • Feb 25, 2013
    thanks for your reply sir. then source doesn't produce any electrons that causes flow of current?
  • rahul69
    @rahul69-97fAOs • Feb 26, 2013
    pr159260thanks for your reply sir. then source doesn't produce any electrons that causes flow of current?
    Source cannot produce electrons, it just create a potential difference which forces the free electrons to move thus creating current.
    Take an analogy: Consider a setup in which we are sending water in pipes in loop using a motor, the water will flow in the loop until the motor is on and stops when it is off. Similar is the case with electrons in the wires.
    Hope it clears your doubts!๐Ÿ˜€
    Good Luck!!
  • pr159260
    @pr159260-4NR0Kn • Feb 26, 2013
    thanks for ur expanation #-Link-Snipped-#.
    @ramani-VR4O43 • Feb 26, 2013
    rahul69Source cannot produce electrons, it just create a potential difference which forces the free electrons to move thus creating current.
    With a difference.
    In a battery at the anode (this is the negative pole in a battery) the metal atoms at the surface give up electrons and go into solution. These electrons move through the external circuit and neutralise the positive ions in the electrolyte at the cathode surface Which is the positive carbon rod or equivalent.
    The overall reaction products have less energy than the starting materials. This chemical energy reduction leads to the potential difference. The number of electrons leaving the cathode exactly equal that consumed at the cathode. In that sense no net electrons are produced.
    Then what leads to the potential difference?
    The difference between the chemical reaction potential at the anode and cathode leads to the voltage generated by the battery.
  • Naman Agarwal
    @naman-42FOIm • Mar 11, 2013
    Good Luck!!
    Then According To Ur Answer, The Charges Get Stagnent At Their Location At The Instant Of No Supply. But There Should Not Be Any Charge(s) Present On Account Of Zero Voltage Difference..What Say??
  • rahul69
    @rahul69-97fAOs • Mar 11, 2013
    naman2511Then According To Ur Answer, The Charges Get Stagnent At Their Location At The Instant Of No Supply. But There Should Not Be Any Charge(s) Present On Account Of Zero Voltage Difference..What Say??
    First of all I said electrons and not charges (and electrons are negatively charged), but at zero potential difference also, electrons (as well as protons) are present, it is not the presence of electrons or protons but the imbalance that creates the charge you are talking about,
    And I think u misunderstood something, could u tell in more detail what is the exact doubt u r having.
  • Naman Agarwal
    rahul69First of all I said electrons and not charges (and electrons are negatively charged), but at zero potential difference also, electrons (as well as protons) are present, it is not the presence of electrons or protons but the imbalance that creates the charge you are talking about,
    Dont Worry ..I Got It..
