  • What will happen if a magnet is placed in between a transmission line?
    Mr.Don
    Member
    Updated: Oct 26, 2024
    CEans,
    I have an another crazy doubt. 😉
    What will happen when a magnet is placed in between a transmission line. What factors will it influence if we place it in between?
  • everett.pattison
    MemberMay 20, 2011
    How is this different than the previous post? Do you mean transmission lines as in power lines?
  • venueee
    MemberMay 20, 2011
    your doubt is well but you dont mention the which type of magnet it is either parmenent or ortificial...........
  • Mr.Don
    MemberMay 20, 2011
    @Venuee I would be happy if you explain Both Sir.
    @everett.Pattison
    When we pass a magnet through a pipe with a copper wire wound around it connected to a LED.The LED will glow. Which means magnets will produce electricity. Now the question is what happens when a magnet is placed in between a transmission line.
    If it conducts then what are the factors its going to effect?
    If it doesn't then why? because when current is applied to metallic strip it will act as a magnet and will it loose its conducting properties after becoming a magnet.(I think No) then where's the energy going.
  • narayana murthy
    MemberMay 21, 2011
    @Dileep:i believe if a magnet is placed in transmission lines there appear some losses in transmission of electricity
    i think i forgotten the name of the effect but i remember that it leads to emf produces on surroundings of wire and it effects a lot in transmission
    in next sem i have subject on this and i have to go with same subject if i see it i will definitely post here
  • Mr.Don
    MemberMay 21, 2011
    Ya I think it must be Ferranti effect but here my doubt is can we use this generated emf to compensate the losses in transmission line.
  • narayana murthy
    MemberMay 21, 2011
    dileep k
    hmmmm may be possible let us think of it but i am not sure because it occurs in air
  • maraitamilan
    MemberMay 21, 2011
    i think only losses will be produced no notable change occurs its just a guess dude
  • Mr.Don
    MemberMay 22, 2011
    @Maraitamilan ok Thanks Dude but some say some magnets conducts and my doubt is if they does can we use them for generating extra power.
  • narayana murthy
    MemberMay 22, 2011
    dileep k
    dileep i think they conduct but they have some conditions of flemings rules and other rules given by great scientists
    so if we satisfy that conditions we can generate as you says
  • lal
    MemberMay 23, 2011
    Lets think of all the factors in this case. Consider only a single transmission line. And a magnet is placed near it.
    Now, current is flowing through the transmission line. whenever there is a flow of current, a magnetic field is set up around it. Since the current is alternating, the magnetic field will also be alternating. And we are having a permanent magnet near it. The magnet is producing a flux too. And it is fixed, that is not alternating. So the alternating flux will now be interacting with the flux generated by the magnet. So I think the magnetic flux by the permanent magnet will be aiding the alternating flux for a half cycle and opposing in the next.
    Impact on the magnet
    * May be it will be vibrating at 50Hz.
    Impact on the line (still thinking)
    * May be there would be mechanical tension
    * The inductance may be affected
  • Saandeep Sreerambatla
    MemberMay 23, 2011
    dileep k
    Ferranti effect is rise of voltage at the receiving end due to load drop or no load.
    This happens in long transmission lines.
    And, regarding your question, it depends on the size of the magnet as far as i know.
    A line which is carrying power will have emf around it a little bit depends on air and moisture so if you place a magnet near by may be some amount of current flow through the magnet.
  • praba230890
    MemberMay 24, 2011
    Ferranti effect got nothing to do at here it's just a name given to a state where the receiving end voltage seems to be more than the sending end voltage.Ferranti effect is due to the voltage drop across the line inductance (due to charging current) being in phase with the sending end voltages. Therefore both capacitance and inductance is responsible to produce this phenomenon.
  • praba230890
    MemberMay 26, 2011
    If you place a permanent magnet between a TL then there will not be any effect. This is because the permanent magnet exerts non varying uniform magnetic field which wont affect the conductor carrying current as per faraday's law(change of flux only have an effect on conductor).
    dileep k
    CEans,
