what will be the volume of gas
vrams
@vrams-AeBdEs โ€ข Oct 26, 2024
Assume a reactor of volume 700 L is filled with water (500L) and given a N2 pressure of 5Kg/cm^2. Then how much volume of gas will be present in remaing space at room temperature if it is a closed reactor? If reactor was heated to 50 degees C what will be the volume of the gas at 50 degrees.
  • vrams
    @vrams-AeBdEs Feb 9, 2010
    where are CE's
    share your ideas.
    Regards
  • 070790vivek
    @070790vivek-09g1Yf Feb 11, 2010
    don't challenge
    u are also a member of it
    is this problem from F.M.?;-)
