  • what is transition capacitance?
    SHRIKANT CRAZY
    SHRIKANT CRAZY
    @shrikant-crazy-PHOc1H
    Updated: Oct 26, 2024
    Views: 1.3K
    Hello all, I am Shrikant - a crazy electrinics engineer from Jalandhar. I want to know details about transition capacitance. can anyone please help me? Any kind of help is appreciated.
  • aarthivg
    MemberFeb 6, 2012
    TRANSITION CAPACITANCE
    A reverse biased PN-junction has a region of high resistivity sandwiched in between two regions of relatively low resistivity. The P-N regions act as the plates of a capacitor and the depletion layer acts as the dielectric
  • SHRIKANT CRAZY
    MemberFeb 6, 2012
    well...thanks for giving the answer but clarify me this why the reverse biased PN JUNCTION has a region of high resistivity?
  • aarthivg
    MemberFeb 6, 2012
    Connecting the P type region to the negative terminal of the battery and the N type region to the positive terminal corresponds to reverse bias.
    FOR HIGH RESISTIVITY:
    Because the p-type material is connected to the negative terminal of the power supply, the <a href="https://en.wikipedia.org/wiki/Electron_hole" target="_blank" rel="nofollow noopener noreferrer">Electron Hole</a> in the P-type material are pulled away from the junction, causing the width of the depletion zone to increase. the N-type region is connected to the positive terminal, the electrons will also be pulled away from the junction. Thus, the <a href="https://en.wikipedia.org/wiki/Depletion_region" target="_blank" rel="nofollow noopener noreferrer">Depletion Region</a> widens, and increases with increasing reverse-bias voltage. This increases the voltage barrier causing a high resistance to the flow of charge carriers, thus allowing minimal electric current to cross the p–n junction.
  • SHRIKANT CRAZY
    MemberFeb 6, 2012
    aarthivg thank you so much
  • lalit.joshi
    MemberFeb 6, 2012
    i think i should also explain mate..... well, when a p-n junction diode as a reverse biased configuration then the negative terminal of battery is connected to the p side of diode and the positive side is connected to the n side. due to which the the electrons are collected to the n side as well as the holes are collected to the p side. due to which the depletion region is increased which works as dielectric having high resistivity and the whole configuration is considered as transition capacitor.
