what is the output of 'c++' code?????
impecable_abhi
@impecable-abhi-6uhMfA โ€ข Oct 26, 2024
void main()
int num=190*300/300;
cout<<"num:"<<num;
explain me !!!!!!what is the logic behind it????
๐Ÿ˜•๐Ÿ˜•๐Ÿ˜•
  • MaRo
    @maro-Ce3knx • Apr 2, 2009
    What is the logic behind what?
  • shalini_goel14
    @shalini-goel14-ASmC2J • Apr 2, 2009
    MaRoWhat is the logic behind what?
    @Maro I guess he/she is trying to ask what is the logic behind the output?
    By the way -what will be the output? C++ users answer Please?
  • Prasad Ajinkya
    @prasad-aSUfhP • Apr 3, 2009
    The answer is logical, the int datatype has a 2byte storage. 2 bytes equals to 16 bits, which equals to a maximum value of 32768 for unsigned int, and 16384 for signed int. Any value higher than this, rolls over and goes to the extreme value (0 for signed and -16384 for unsigned). It keeps on doing this until the overflow does not occur.
    190 * 300 creates an overflow of the int datatype. So the first iteration gets you 57000-16384, which is somewhere near 40000. Now it switches to -16384 and starts counting towards 16384. Once it reaches 16384, there are some 7800 odd more to go, so it switches back to -16384 and finishes off at -8536.
    This is then divided by 300. To get -28.
    I checked this against the code, and split it up and checked the logic as well. Works out.
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Apr 3, 2009
    impecable_abhivoid main()
    cout<<"num:"<<num;
    I compiled the above code for 32-bit machine and then executed the code and it gave me "190" as output which i feel is desired output.
    But as you have posted this query so i feel you are not getting the desired output. Could you post more details like what output you are getting? Which compiler you are using? Is it 16-bit or 32-bit compiler?
    I am taking below guess for the issue you may be facing (i might be incorrect):
    - You are using some 16-bit compiler.
    - The size of data type 'int' on such compiler is 2 bytes, so the value of variables will range from -32768 to +32767.
    - In the given statement
    there are operators * and / having same precedence so based on the associativity for these the operations will be executed from left to right. Hence result for * will be computed first and the / will be computed.
    - "190*300" results '57000' which exceeds the range (upper limit is +32767). Due to this overflow the variable now contain some -ve value and hence '/' is then not resulting desired output.
    -Pradeep
  • MaRo
    @maro-Ce3knx • Apr 3, 2009
    Please give more info about your machine & compiler you using.
  • Prasad Ajinkya
    Pradeep, I ran this code on TurboC, the same compilers which our colleges used to have. It takes a pain to run it on Vista ๐Ÿ˜€, but it runs still the same. So, yes I am using a 16 bit compiler.
    My bad, it is -32767 to +32767. Nonetheless, the calculations remain the same, except it overflows only once ๐Ÿ˜€
    And TurboC first tackles the * operator since it needs to know the exact nature of the numerator to do the division.
  • pradeep_agrawal
    MaRoPlease give more info about your machine & compiler you using.
    I am using a 32-bit gcc compiler and running it on 32-bit RHEL5 machine. For using gcc on Windows download cygwin or djgpp2. For compiling code use gpp compiler.
    kidakakaI ran this code on TurboC, the same compilers which our colleges used to have. It takes a pain to run it on Vista ๐Ÿ˜€, but it runs still the same. So, yes I am using a 16 bit compiler.
    Actually i was replying to query from impecable_abhi but by the time i could have posted you had already replied to the mail๐Ÿ˜€
    Looks like impecable_abhimight be facing the issue with using the compiler that generates 16-bit code (might be turboc).
    -Pradeep
  • rama_krish627
    @rama-krish627-LuiiO6 • Apr 5, 2009
    I run this code and O got 190 as the out put. why you are not getting this output. Let me tell you the details of the compiler you are using. So that we will come out with the solution.
  • silverscorpion
    @silverscorpion-iJKtdQ • Apr 5, 2009
    I use turbo C 16 bit compiler and I got -28 as the answer.
    How will you get 190 as the answer? What is the compiler you are using??
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Apr 6, 2009
    silverscorpionI use turbo C 16 bit compiler and I got -28 as the answer.
    I am using 32-bit gcc compiler with which i am not facing the issue.
    As i mentioned in the post
    and
    the issue will be coming with with compilers generating 16-bit code because in i16-bit the size of int is 2 byte and the value ranges from -32768 to 32767.
    Here depending on the operator precedence and associativity "190*300" will be computed first resulting '57000' which is greater then the upper limit of int '32767' and causes overflow and hence resulting in some incorrect value.
    The problem will not come with compilers generating 32-bit code (e.g., 32-bit gcc compiler) as that will have size of int as 4 byte and the value can range from รขยˆย’2147483648 to 2147483647.
    Let me know if it need more explanation of any item.
    -Pradeep
  • silverscorpion
    @silverscorpion-iJKtdQ • Apr 6, 2009
    Ok. Now I understand. It's clear.
    Thanks!!
  • impecable_abhi
    @impecable-abhi-6uhMfA • Apr 8, 2009
    shalini_goel14@Maro I guess he/she is trying to ask what is the logic behind the output?
    thanx salini for understanding me well.....
  • slashfear
    @slashfear-tSWzpz • Apr 14, 2009
    Hi abhi (Guess thats your name!!),
    void main()
    cout<<"num:"<<num;
    ok so you wanna know how the code work here is the answer:
    First your a creating as well as assigning a value to the variable (num) of type integer.
    here you assign the value of num as num=190*300/300, so according to operator precedence * (multiply) as well as / (divide) has the same operator precedence value. so First 190*300 is calculated which results in 57000 and then the resulting value (57000)is divided with 300. Hence, 57000/300 results in 190, so the value of num is assigned to 190.
    Now, in the next line of code :
    cout<<"num:"<<num;
    cout followed by << is used to display the content in the display or console. so what we have given here is num: , the value given within the " " is a junk, so what ever we give with in the double coats will be displayed as it is in the console (Remember the values with in the double coats will be ignored by the compiler and hence it will be displayed as it is given in the console)
    so <<num; in the code is going to display the value stored in the variable (num)
    so the output of the code is: num: 190
    Hope It made scene to you !!! If you have further doubt please do reply buddy!!
  • slashfear
    Hi,
    The logic behind the code??
    There is no logic behind the code buddy dont complicate your self
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Apr 14, 2009
    slashfearHi abhi (Guess thats your name!!),
    The output does not comes as 190 when user compiles the code to generate executable for 16-bit machine. See below post for more details:
    -Pradeep
  • slashfear
    @slashfear-tSWzpz • Apr 15, 2009
    pradeep_agrawalThe output does not comes as 190 when user compiles the code to generate executable for 16-bit machine. See below post for more details:
    -Pradeep
    Hey Pradeep,
    Ya what you say is right, in 16 bit machine when you try to compile the program it would cause overflow as the range of integer is -32768 to 32767. And you would get the answer as 190 when you use a 32 bit machine as integer has the range รขยˆย’2147483648 to 2147483647. ๐Ÿ˜‰
  • slashfear
    Hi abhi,
    When your using a 16 bit machine you have to change the data type as long int instead of int so that you would get the desired output. ๐Ÿ˜‰
