  • KARAD123
    @karad123-P0ab75 • Dec 26, 2011
    hope to get the answer to my question about tranmission voltage soon..
    @harshad-ukH5ww • Dec 26, 2011
    I heard of HVDC transmission in India. Not sure about exact figure. Get information about HVDC in India.
  • Suresh Manickam
    @suresh-manickam-e2WLRH • Dec 26, 2011
    10,000 volts in main stream and 12-220,240 V in down stream.
  • lal
    lal
    @lal-R60Xjx • Dec 26, 2011
    I remember reading that very long distance AC transmission voltages in India are 110kV and 230kV.
    Edit : I figured out the above statement is presently not true and it is 765kV now.
  • insane.nick
    @insanenick-PoP7BE • Dec 26, 2011
    hi KARAD
    The highest transmission volatage in India is 765kV ac. The highest voltage in the case of DC transmission is +/- 600 kV.
  • KARAD123
    insane.nickhi KARAD
    ok... i guess even i read d same sumwhere.. thanks...
  • KARAD123
    thanks every1...
    the teacher in my college asked us an question... which type of circuit is present in radios and televisions? ac or dc? I'm not sure about its answer... can any1 help?
    @thebigk • Dec 26, 2011
    KARAD123thanks every1...
    Why not try to find answer on your own ๐Ÿ˜€
  • KARAD123
    The_Big_KWhy not try to find answer on your own ๐Ÿ˜€
    i didnt get a proper answer... thats y i asked....
  • Suresh Manickam
    In both radio and TV, DC is used. to explain clearly contact me.
  • KARAD123
    Suresh ManickamIn both radio and TV, DC is used. to explain clearly contact me.
    ok...
    @thebigk • Dec 27, 2011
    Why can't everything be discussed here? Explain what you've to explain here. Larger audience will benefit.
  • Suresh Manickam
    @suresh-manickam-e2WLRH • Dec 27, 2011
    Its too large post here.
  • insane.nick
    @insanenick-PoP7BE • Dec 29, 2011
    Hi KARAD 123 you think you are so smart ...
  • KARAD123
    @karad123-P0ab75 • Dec 30, 2011
    insane.nickHi KARAD 123 you think you are so smart ...
    excuse me... wat did i say? i just asked a doubt?
  • durga ch
    @durga-TpX3gO • Dec 30, 2011
    @ All, please be clear and appropriate in your comments
    Please follow rules of not spamming the thread with personal opinions rather try contributing constructively to the thread.
  • narayana murthy
    @narayana-z4W16q • Dec 31, 2011
    actually transmission from generating station is 400kv and in between there are about many step down or step up's hope i am clear in dc there is around 1000kv because it has to travel long distance
    @thebigk • Dec 31, 2011
    That was inappropriate.
  • insane.nick
    @insanenick-PoP7BE • Jan 4, 2012
    hey admin and KARAD 123 ehen i was give you the correct answer then you share this post..
    then i was share this ...
    okkkkkkkkk if you think i am wrong then i am sorry..............
  • naga lakshmi
    @naga-lakshmi-wryexy • Jan 14, 2012
    I think its based on ac circuits ,because radios & televisions based on the principle frequency .
    frequency concept is only on an ac circuits.
  • akpower
    @akpower-WAuq3q • Jan 15, 2012
    Hi Karad123,
    Exact answers to your queries are
    1]Transmission voltage in India (highest) is 750KV AC and these lines are erected by Power Grid Corporation for interstate connections throughout India. However work on 800KV is also in progress.
    2] DC transmission voltage (highest) in India is 600KV .This has restriction due to conversion i.e. AC/DC & inversion i.e. DC/AC for bulk power transmission.
    3] Radio circuits use both. AC & DC.When AC supply is available ,the instruments(rectifier) convert AC to DC from 230volts to 6 volts for operating the other electronic circuits namely,amplifiers, converters,mixers etc.Since all semiconductors require only small DC voltage to drive them.
    Hope it satisfies your query.
  • KARAD123
    @karad123-P0ab75 • Jan 17, 2012
    thank you..
  • lalit.joshi
    @lalitjoshi-7OYXJa • Feb 4, 2012
    sure.... listen, a RLC circuit is used in radio and television to catch a proper frequency for visulisation as well as audio. at last both signals are synchronised. this is the working. RLC circuit works in dc so circuit is dc but creat oscillations like ac.
  • SHRIKANT CRAZY
    @shrikant-crazy-PHOc1H • Feb 5, 2012
    hi karad 123
    hey.......i don't know how much you are benefiting from your questions but i'm very much glad to know this type of interseting questions. thank you very much.........
  • jarpala venkates
    @jarpala-venkates-IkOpqx • Aug 4, 2015
    thank you for giving this valuable information.
  • Ganeshkumar.R
    @ganeshkumarr-LujHtJ • Sep 8, 2015
    Thankyou for valuable qes and answer I request to post more information
  • alok raj
    @alok-raj-xAoN3j • Sep 16, 2015
    nice to have such intresting queries.
    The Generator terminal voltage is stepped up by the power station transformer to a higher voltage (115 kV to 765 kvAC, varying by the transmission system and by country) for transmission over long distances.
    IN dc its up to 600kv.
  • Bijay Krishna Nandi
    @bijay-krishna-nandi-z3OnlN • Sep 28, 2015
    See as per the question- 800 kv HVDC transmission line is recently charged from Biswanath Chariali to Agra ( North East) first ever in India. However in AC transmission system it is 765KV generally both are erected and charged by PGCIL officials. I hope I have answered.
  • vamsi kancharla
    @vamsi-kancharla-kL9oxU • Oct 1, 2015
    KARAD123What is the highest transmission voltage in India? I didnt get any exact answer.
    AC- transmision line --1200KV comissioned 6 moths back
    traditional ac lines will be in the range of 132KV,220KV,765KV
    132KV lines are majorly laid by the state governaments
    220KV by power grid used to connect load centres from generation points
    765Kv-1200Kv for high power transmission
    DC-line--800v, for power transmission between load dispatch centres but not to load points
    25KV single phase for railway lines
  • J4ever
    @j4ever-3i0cGj • Jul 8, 2016
    vamsi kancharlaAC- transmision line --1200KV comissioned 6 moths back
    1200kV testing substation is at Bina In Madhyapradhesh not for transmission.
