What is the difference between expansion and construction joint?
Feather
@feather-OCZy0g • Oct 26, 2024
can somebody please explain the difference between expansion and construction joint with simple example? what are its practical usages?
  • CIVILPRINCESS
    @civilprincess-308hDv May 30, 2012
    you must be meaning "expansion and contraction joints" 😀 They just help the structure to expand or contract according to the surrounding temperatures without the formation of any stresses.
    The expansion joint may have any material capable of taking compression like rubber or any other material. The bridge girders (for example) are built in sections and joined with these joints in between. So if due to high temperature the reinforced concrete tends to expand, the expansion is allowed and the forces due to these expansion and contraction is made less. once the temperature comes back to the normal the material comes back to the original position as it was earlier.
    Hope you understand the concept 😀
  • Mohamed Amir
    @mohamed-amir-GNsD1j Nov 3, 2012
    construction joint is a separation of either vertical or concrete pours designed to offer movement in case of wind loading or other loads so as not to compromise the integrity of the concrete structure itself. The construction joint is usually joined together by non-metallic strap to hold the two slabs in place; at the same time giving flex when there is movement
    [​IMG]
    expansion joint or movement joint is an assembly designed to safely absorb the heat-induced expansion and contraction of various construction materials
    [​IMG]
  • rekcah
    @rekcah-TiEtTy Nov 4, 2012
    Concrete expands and shrinks with changes in moisture and temperature. The overall tendency is to shrink
    and this can cause cracking at an early age. Irregular
    cracks are unsightly and difficult to maintain but generally do not affect the integrity of concrete. Joints
    are simply pre-planned cracks. Joints in concrete slabs
    can be created by forming, tooling, sawing, and placement of joint formers.
    Some forms of joints are:
    a. Contraction joints – are intended to create weakened planes in the concrete and regulate the location where cracks, resulting from dimensional
    changes, will occur.
    b. Isolation or expansion joints – separate or isolate
    slabs from other parts of the structure, such as walls,
    footings, or columns; and driveways and patios
    from sidewalks, garage slabs, stairs, lightpoles and
    other points of restraint. They permit independent
    vertical and horizontal movement between adjoining parts of the structure and help minimize cracking when such movements are restrained.
    c. Construction joints – are surfaces where two successive placements of concrete meet. They are typically placed at the end of a day’s work but may be
    required when concrete placement is stopped for
    longer than the initial setting time of concrete. In
    slabs they may be designed to permit movement
    and/or to transfer load. The location of construction joints should be planned. It may be desirable to achieve bond and continue reinforcement
    through a construction joint.
    WHY THIS JOINTS CONSTRUCTED?
    Cracks in concrete cannot be prevented entirely, but
    they can be controlled and minimized by properly designed joints. Concrete cracks because:
    a. Concrete is weak in tension and, therefore, if its
    natural tendency to shrink is restrained, tensile
    stresses that exceed its tensile strength can develop,
    resulting in cracking.
    b. At early ages, before the concrete dries out, most
    cracking is caused by temperature changes or by
    the slight contraction that takes place as the concrete sets and hardens. Later, as the concrete dries,
    it will shrink further and either additional cracks
    may form or preexisting cracks may become wider.
    Joints provide relief from the tensile stresses, are easy
    to maintain and are less objectionable than uncontrolled or irregular cracks.
