  • What is the difference between BJT and power BJT?
    renu sharma
    renu sharma
    @renu-sharma-C1JNn9
    Updated: Oct 27, 2024
    Views: 3.2K
    what is the difference between BJT and power BJT? what are the applications of each of them?
  • Jeffrey Arulraj
    MemberJun 21, 2013
    BJT and power BJT are both transistors having different operating voltage levels
    For an simple BJT like BC107 the maximum effective operating voltage is 30 V
    Whereas the operating voltage of some of power BJT a few 100 volts
  • renu sharma
    MemberJun 21, 2013
    what are the applications of each?
  • arunchary
    MemberJun 22, 2013
    A power transistor is physically larger, and capable of carrying more current without melting or burning up. Usually a power transistor has a heatsink attached to help remove heat from the device and keep it cool.a normal transistor cant, coming to applications transistors are used in amplification and switching operation and power transistors are in battery charger circuits and power supply circuits(smps) to hold large amount of currents like irf4905 carries heavy drain currents and more power dissipation up to 200w etc.better to go through the datasheet to get better understanding between normal and power transistors.........😀
  • Jeffrey Arulraj
    MemberJun 22, 2013
    This resource I found is of little help do have a peep into it this will enlighten you about the difference between the two BJT's a little
  • Ahsanul haque
    MemberOct 18, 2013
    Bipolar junction transistor[BJT] types of transistor depends on two types of semiconductor. BJT works like as amplifiers or Oscillators. BJT works as individual discrete components or part of intefrated circuit. Power BJT allows full controm over turn on and turn off operations . I would recommend u that if you need more information then visit #-Link-Snipped-#
  • Jeffrey Arulraj
    MemberOct 18, 2013
    @#-Link-Snipped-# There is one reason why we still prefer BJT over MOSFET.
    Though Mosfet has better input characteristic it lacks one thing that is thermal stability
    So for lower end applications and also to bring cost of construction down We prefer BJT over Mosfet
    power Mosfet need coolers externally But most of the power BJT have more stable operation in higher temperature and so they don't need more cooling apparatus
