  • What is the depth of foundation for my house in rocky area?
    dhavaskar
    Member
    Updated: Oct 26, 2024
    Views: 1.2K
    hello friends,
    I am constructing my house in a place in which the ground has lot of rocks, stones.....
    My engineer is unwilling to go for some good depth in the foundation for my house, planned for ground and first floor only. I am very much confused & worried.
    What should be the depth of foundation for the construction of my house proposed with only ground and first floor?
  • Jeffrey Arulraj
    MemberNov 12, 2012
    Mostly rocky areas has very high soil bearing capacity based on that the depth of the foundation is often very less
    Do post your area and also check Google for the soil bearing capacity for your area and then post the info here I am sure the CE architects will look over your issue
  • dhavaskar
    MemberNov 12, 2012
    jeffrey samuel
  • dhavaskar
    MemberNov 12, 2012
    hello,
    thanks a lot for the advise. i am building a house in Nityanand Colony, Near Guruprasad Nagar, BELGAUM, Karnataka, INDIA. i am not sure about the info asked by you. with lot of regards & Thanks...
  • Mahendra Kumar Kain
    MemberJan 26, 2013
    dhavaskar
    hello friends,
    MemberJan 26, 2013
    Sufficient depth to guard against overturning of the structure is also required even if good bearing capacity is available at shallow depth in rocky areas.
  • Naseeruddin4
    MemberSep 3, 2015
    Mahendra1953
    How to calculate sufficient depth
