Is ready boost work like as a external RAM or something else ???0
Dear guest, you must be logged-in to participate on CrazyEngineers. We would love to have you as a
member of our community. Consider creating an
account or login.
Member • Oct 19, 2012
It just stores the less frequently required files onto the external memory so that some of the primary RAM can be cleared up. This could give a little amount of performance boost.
The actual RAM is extremely faster and the USB storage device is no match to the speed of RAM. Don't think an 128 MB ram + 16 GB external storage device configured with ready boost will make a huge difference to the performance. It'll surely make some difference, but negligible. Getting a more RAM is better solution as they are dirt cheap these days.Are you sure? This action cannot be undone. -
Member • Oct 20, 2012
when i insert pen drive and select readyboost then my pen drive show ready boost and pen drive store space up to three GB which is not deleted. it should be deleted or not . what i have to do? otherwise i have to delete it other system. after use ready boost then what i have to do?? when i remove my pen drive then ready boost should be off or not ?? i thought readyboost store cache file this is right or not ??Are you sure? This action cannot be undone. -
Member • Oct 22, 2012
i think a pendrive cannot store cache file! Cache memory is present between processor and main memory. It holds most recently and frequently used files so as to decrease memory acess time!
Since readyboost stores less frequently used files so as to clear ram to some extent hence i think it would be incorrect to say that it holds cache file.Are you sure? This action cannot be undone. -
Goto pendrive properties and disable for ready boost.or insert pendrive in xp/linux system and format it.arjun srivastavwhen i insert pen drive and select readyboost then my pen drive show ready boost and pen drive store space up to three GB which is not deleted. it should be deleted or not . what i have to do? otherwise i have to delete it other system. after use ready boost then what i have to do?? when i remove my pen drive then ready boost should be off or not ?? i thought readyboost store cache file this is right or not ??Are you sure? This action cannot be undone.
