    @thebigk Mar 11, 2013
    motameethcan i know what is differnce between electric and electronics
    Always search before you post. Check following discussion - #-Link-Snipped-#
  • vamsi kancharla
    @vamsi-kancharla-kL9oxU Mar 14, 2013
    electrical deals with motors,transformers and electrical power
    electronics deals with maily R L C and diodes,transistors
    elecrical also deals with R L C
    @thebigk Mar 14, 2013
    Electrical engineering typically deals with generation, transmission, distribution of electricity and electrical machines in depth. Electronics engineering is mostly about circuits and applications of electricity in at smaller magnitude.
    #-Link-Snipped-# - do you have further questions or your query has been answered?
  • kranthikumar1425
    @kranthikumar1425-9q40mf Mar 14, 2013
    what is an induction machine?
    kranthikumar1425what is an induction machine?
    An Induction Motor would be an induction machine. Please refer to the textbooks for details on how Induction motor works and how it's built up.
  • [Prototype]
    @prototype-G9Gn5k Mar 16, 2013
    Kaustubh KatdareElectrical engineering typically deals with generation, transmission, distribution of electricity and electrical machines in depth. Electronics engineering is mostly about circuits and applications of electricity in at smaller magnitude.
    Electrical is as well about circuits. The differentiating factor is, electronics or better words are, microelectronics is all about SEMICONDUCTOR devices and their applications. That semiconductor word is most important as thats what seperated electronics from electrical. So anything involving semiconductor is electronics. If you use it on high voltages, you may notice its still electronics, but power electronics. Generally theres a misconception that if you work on high voltages its electrical, its not!
    @thebigk Mar 16, 2013
    That is correct. I only talked in a much broader perspective. I'm not sure if electronics engineers get to study HV lines and machines. I might be wrong.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Mar 16, 2013
    Electronics has a branch called power electronics which deals completely with HV But in the whole some end it is just a small piece I would say
  • Geetam Bharadwaj
    @geetam-bharadwaj-yU9kPh May 6, 2013
    In a simple way-
    Electrical deals upon the current carrying in a Conductor while Electronics deals upon the current carrying in a semiconductor.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP May 20, 2013
    Geetam BharadwajIn a simple way-
    Then is SCR carrying current in Semi conductors and Aluminium is not a semi conductor is used in Schottky diode
  • pothedarvamsi
    @pothedarvamsi-uhGh3Q May 26, 2013
    I do accept all the above replies from various "crazy engineers" ok.
    Electrical things use POWER to start and to run them
    where as
    Electronics uses VOLTAGE majorly.
    Examples:
    1.Computer or Mobile is an ELECTRONIC DEVICE.
    Computer may given power to start but in SMPS we will be finding Step-down transformers to reduce for required and vairous converters used to get voltage to be used by various components in computer.
    2.Transformer or Generator is an ELECTRICAL DEVICE.
  • Geetam Bharadwaj
    @geetam-bharadwaj-yU9kPh May 27, 2013
    Two theory describes current flow. The CONVENTIONAL theory commonly used for automotive systems says that current flows from +ve to -ve. i.e the excess electrons from an area of high potential flows to an area of low potential.
    The second is the ELECTRON theory basically used in electronics says that current flows from -ve to +ve.
    i.e excess electrons cause an area of -ve potential and flows towards an area lacking electrons, an area of +ve potential to balance the charge.
