  • what is ADT??
    samaira
    samaira
    @samaira-P4RsEf
    Updated: Oct 25, 2024
    Views: 1.4K
    what do u mean by Abstract data types.??And whats the relation between ADT and data structures???😕And one more thing i m 'to be comp engineer' so can anyone tell me all the things about computer that an engineer should know.Plz help
  • saurabh2486
    MemberAug 16, 2009
    <a href="https://en.wikipedia.org/wiki/Abstract_data_type" target="_blank" rel="nofollow noopener noreferrer">Abstract Data Type</a>
    hope this will help
  • saurabh2486
    MemberAug 16, 2009
    and for ur 3rd query u should be able to do coding and able to understand that how everything in computer works etc etc . if you have any problems u can ask lol
  • aponjon
    MemberAug 17, 2009
    abstract data type or abstract data structure is a <a href="https://en.wikipedia.org/wiki/Mathematics" target="_blank" rel="nofollow noopener noreferrer">Mathematics</a> model for a certain class of <a href="https://en.wikipedia.org/wiki/Data_structure" target="_blank" rel="nofollow noopener noreferrer">Data Structure</a> that have similar behavior; or for certain <a href="https://en.wikipedia.org/wiki/Data_type" target="_blank" rel="nofollow noopener noreferrer">Data Type</a> of one or more <a href="https://en.wikipedia.org/wiki/Programming_languages" target="_blank" rel="nofollow noopener noreferrer">Programming Languages</a> that have similar <a href="https://en.wikipedia.org/wiki/Semantics" target="_blank" rel="nofollow noopener noreferrer">Semantics</a>. An ADT is defined indirectly, only by the operations that may be performed on it and by mathematical constraints on the effects (and possibly <a href="https://en.wikipedia.org/wiki/Computational_complexity" target="_blank" rel="nofollow noopener noreferrer">Computational Complexity</a>) of those operations<a href="https://en.wikipedia.org/wiki/Abstract_data_type#cite_note-liskov-0" target="_blank" rel="nofollow noopener noreferrer">Abstract Data Type Cite Note Liskov 0</a>. For example, an abstract <a href="https://en.wikipedia.org/wiki/Stack_data_structure" target="_blank" rel="nofollow noopener noreferrer">Stack Data Structure</a> could be defined by two operations: push, that inserts some data item into the structure, and pop, that extracts an item from it; with the constraint that each pop always returns the most recently pushed item that has not been popped yet. When <a href="https://en.wikipedia.org/wiki/Analysis_of_algorithms" target="_blank" rel="nofollow noopener noreferrer">Analysis Of Algorithms</a> of algorithms that use stacks, one may also specify that both operations take the same time no matter how many items have been pushed into the stack, and that the stack uses a constant amount of storage for each element.
