@navathe-8fNDWG • Jun 14, 2012
It is a machine or a device used for raising,compressing or transferring fluids. Apllications:Industrial,residential,commercial and other applications. -
@ramani-VR4O43 • Jun 14, 2012
I trust that this a serious question. It is difficult to become a mech E without coming across some pump or other. Any fluid moving application (or even slurries) uses some kind of pump or other.
<a href="https://www.engineersedge.com/pumps/pump_menu.shtml" target="_blank" rel="nofollow noopener noreferrer">Pump Types | Pump Applications Pump Design Equations</a> -
@aarthivg-HH344f • Jun 14, 2012
A pump is a device, where mechanical action takes place for moving the liquid.
pumps are used in water supply, irrigation, gasoline supply, <a href="https://en.wikipedia.org/wiki/Air_conditioning" target="_blank" rel="nofollow noopener noreferrer">Air Conditioning</a> systems, <a href="https://en.wikipedia.org/wiki/Refrigeration" target="_blank" rel="nofollow noopener noreferrer">Refrigeration</a> , chemical movement, <a href="https://en.wikipedia.org/wiki/Sewage" target="_blank" rel="nofollow noopener noreferrer">Sewage</a> movement, flood control, marine services. -
@ce-designer-BWq0yl • Jun 15, 2012
I general question requires a general answer.
A pump is a device which is used to increase the enerygy of fluids. -
@jaspal-rautela-yw5rJz • Jun 15, 2012
types of pump? -
@ramani-VR4O43 • Jun 15, 2012
Why don't you visit the link of engineers' edge provided above and read up? It has enough material to keep you busy for a few days.jaspal rautelatypes of pump? -
@nibhani-wLU5Ju • Jun 16, 2012
in simple language u can say that a pump is a device which is used to change mechanical energy in to potential energy by increasing the pressure of fluid....jaspal rautelawhat is pump? what is its application? -
@jaspal-rautela-yw5rJz • Jun 16, 2012
where it is used? -
@zaveri-5TD6Sk • Jun 17, 2012
water or any liquid usually flows from a higher level to a lower level. but a pump is a device which makes the reverse of this possible.
pumps are used everywhere, and its types are as diverse as I.C engines
based on the types of applications there are different types.
pumps are used for residential applications, where they are used for moving water and sewage.
in industrial applications they are used in hydraulic systems, powerplants , etc.
and in automobiles they are used for fuel injection, power steering etc. -
@ce-designer-BWq0yl • Jun 18, 2012
Pumps are characterized into two major categories:jaspal rautelatypes of pump?
Positive Displacement vs Centrifugal.
They can further be broken down into sub-categories. -
@ramani-VR4O43 • Jun 18, 2012
Ejectors, magneto hydro dynamic devices and other impulse based pumps do not fall into these large classes of pumps.CE DesignerPumps are characterized into two major categories😛ositive Displacement vs Centrifugal.
<a href="https://repository.upenn.edu/cgi/viewcontent.cgi?article=1129&context=meam_papers" target="_blank" rel="nofollow noopener noreferrer">Magneto hydrodynamic (MHD) pump fabricated with ceramic tapes</a> -
@nibhani-wLU5Ju • Jun 18, 2012
it is used to raise the level of fluid...u can see in ur practical life that in room cooler a pump is used which is for raising the level of water...and it increases the pressure of fluid a bit...u can see in the problem of thermodynamics that pump work is genrally neglacted because it works very less to increase pressure and increase a little pressure...genrally it is used to raise the level of fluid from a lower height to a higher height it is the main work of pump... -
@nibhani-wLU5Ju • Jun 23, 2012
u
can see the use of pump in ur room cooler ,in this it suck water and raise it to a definite height to wet...jaspal rautelawhere it is used? -
@kedar-crbktt • Jun 25, 2012
Pump is a device used to pump water from lower level to higher level. -
@zaveri-5TD6Sk • Jun 25, 2012
And here is the difference between these two types :CE DesignerPumps are characterized into two major categories:
positive displacement : supplies a given quantity of fluid periodically. they include the reciprocating pump, which employs the crank-slider mechanism, the gear pump, etc.
dynamic or centrifugal: can supply any amount of fluid at any time. they include the centrifugal pumps in which the main working member is the impeller.
If a positive displacement pump, is used in a hydraulic circuit, then it would be required to include a pressure-relief valve too, because if the pump keeps working and all the valves in the circuit are closed, then pressure keeps building up, leading to the explosion of either the pump or the pipes, based on which is of a stronger design.
but if a centrifugal pump was used , and if all the valves are closed , then the impeller would just rotate, without building any excess pressure in the lines.
