@jeffrey-xA7lUP • Nov 4, 2012
What happens when two Capacitors are connected in parallel ?
The same scenario here friend
But I am not sure it is feasible as the output power will be very less than the input power so there are a lot of power dissipation unwantedly here due to circuit Resistance -
@prashanth463-bHrSPU • Nov 4, 2012
actually i tried this experiment in my last sem, where i have connected two DRPS in parallel, where one of the DRPS's voltage was 10V and its current was set to 5A and the other DRPS's voltage was 15V but i don't remember the amount of current i have setjeffrey samuelWhat happens when two Capacitors are connected in parallel ?
after i switched on the circuit, the voltage in the 1st drps changed to 15V, how was this possible?
and sorry for my silly questions 😛 -
The nodal voltage is to be considered here friend
The effective node voltage at the point of the junction of two parallel Voltage sources will be the final output voltage delivered
That is why there was a drop in the voltage of the first battery
