@anand-tamariya-DnfjEX • Mar 3, 2013
Electricity in the form of current flows from high potential to low potential. So when these two points are not connected i.e. nothing is plugged, electricity is maintained as potential difference.
@jeffrey-xA7lUP • Mar 4, 2013
There will always be a difference in potential between the two points But NO CURRENT will flow between the points
@prashanth463-bHrSPU • Mar 9, 2013
nothing happens, the electrons just waiting for a conducting medium to reach ground/other terminal
@vibhor-one-zP13jP • Mar 10, 2013
if there is no buyer then no seller
@mallumatmari-e7iytu • Mar 11, 2013
It will be like no load condition of transformer, some energy is required to maintain potential difference.
@anand-tamariya-DnfjEX • Mar 11, 2013
mallumatmariIt will be like no load condition of transformer, some energy is required to maintain potential difference.
Practically, that's not correct. Primary winding of transformer doesn't have zero resistance. Hence, power is consumed by a transformer even if there is no load - the reason it's advised not to leave your charger( or any device using transformer) plugged into socket after charging is done.
@mallumatmari-e7iytu • Mar 12, 2013
Anand TamariyaPractically, that's not correct. Primary winding of transformer doesn't have zero resistance. Hence, power is consumed by a transformer even if there is no load - the reason it's advised not to leave your charger( or any device using transformer) plugged into socket after charging is done.
what i mean is even after
consider primary winding resistance as 0, we need continuous supply of AC Input for maintaining potential difference.
