  • What are artificial rains and how they are created?
    ISHAN TOPRE
    ISHAN TOPRE
    @ishan-nohePN
    Updated: Apr 16, 2011
    Views: 1.5K
    A few days ago I read about artificial rains being developed by scientists. Anyone got any idea how this is done?
    Hail, lightning and gales came through the state's eastern region this summer thanks to scientist-puppetmasters.
    As part of a secret program to control the weather in the Middle East, scientists working for the United Arab Emirates government artificially created rain where rain is generally nowhere to be found. The $11 million project, which began in July, put steel lampshade-looking ionizers in the desert to produce charged particles. The negatively charged ions rose with the hot air, attracting dust. Moisture then condensed around the dust and eventually produced a rain cloud. A bunch of rain clouds.
    On the 52 days it rained in the region throughout July and August, forecasters did not predict rain once.
    While fascinating, this is not the first time scientists have attempted to mess with Mother Nature. China has been tinkering with cloud seeding for years, not always successfully.
    But the idea that countries in the Middle East could actually create rain in this water-poor region could go a long way to solving the area's problems with drought and is considered to be cheaper than desalination. But how controllable the weather can be is still in doubt, and the consequences of meddling with nature at this level are yet to be seen.
    Source: <a href="https://newsfeed.time.com/2011/01/03/scientists-create-52-artificial-rain-storms-in-abu-dhabi-desert/" target="_blank" rel="nofollow noopener noreferrer">Scientists Create 52 Artificial Rain Storms in Abu Dhabi Desert | TIME.com</a>
  • ISHAN TOPRE
    MemberApr 16, 2011
    Similarly I heard a news last year that Russian Air force now have the capability of making artificial rains. How is it possible? Anyone got any technical detail about it?
    ishutopre
    MGR, the actor-CM of Tamilnadu was a remarkable person. He tried all sorts of outlandish schemes.
    Harvesting Ocean Thermal Power, recharging ground water level by pumping rain water into the ground through bore wells during heavy rains and creating rain by cloud seeding with Silver Chloride smoke were a few of his pet projects.
    The rain is natural. In the sense that it is water available in the atmosphere that gets precipitated. The water is not created from the elements. Unless there is available moisture the idea will not work. What is being done is to provide nucleation sites, which is a well known chem., eng., process for condensation.
    Bioramani
  • ftradeonline
    MemberMay 3, 2011
    i dont think it would work for cooling the climate though...
    even if the rain cools the earth, the heat generated when producting such rain would outweigh its cooling affect, according to thermodynamics.
    <a href="https://fx-tradeonline.com/what-is-the-best-fx-indicator" target="_blank" rel="nofollow noopener noreferrer">What Is The Best FX Indicator?</a>
  • maria flor
    MemberMay 3, 2011
    In some parts of Philippines we use cloud-seeding during summer season.😀
  • PraveenKumar Purushothaman
    MemberMay 3, 2011
    Its made by mixing Sulphur or Nitrous oxide into the rain...
  • silverscorpion
    MemberMay 3, 2011
    I believe the most common chemical used in creating artificial rain is Silver Iodide.
  • jhnmichle
    MemberMay 3, 2011
    it's not practically possible.
  • IITBian 62yrs
    MemberJun 23, 2012
    Some years ago (not more than 3) I read an article which said that one innovator has found a very cheap
    and simple method for artificial raining. It works mostly on periphery of Western Ghats on East side, the region is called "rain shadow" as monsoon clouds empty water on west side of Ghats and so this east side remain rain-less.The innovator used large sheet metal box with dimensions of 4ftx4ftx2ft high. The box had grill on bottom and open on top. Fire-logs or dry wood pieces found rural area are filled in the box along with furnace coal. The fire is started with small amount of kerosene and 2-3 hand blowers are worked by people to blow the fire. Once the logs are lighted properly coal also get lit well good fire sends flames high. The aim is to achieve temperature of 800 degrees centigrade at which the common salt evaporates. some 10-15kg common salt is kept on standby and when flames start real good salt is sprinkled in fire evenly and again more logs are added and air blown by hand blowers. This furnace carries
    the salt vapour up about 80ft or more and then aided by thermal currents and reaches the clouds about 1km up. As soon as salt vapour strikes clouds it absorbs moisture and coalesce into droplets which seed the rain. The experiment were 80% successful and expense on each trial was about Rs.8000/-.
    I have been not able to find that article in Google. So if anybody has found please send me link or reference.
    IITBian 62yrs
    Some years ago (not more than 3) I read an article which said that one innovator has found a very cheap. I have been not able to find that article in Google. So if anybody has found please send me link or reference.
    I did come across a rather similar trial by the Met Dept of India while studying in Andhra 'Varsity in the late 50s. The work apparently started in Maharashtra. All that was done was to have a small steam generator continuously leaking a small jet of steam non stop 24 x 7 at a single location. The idea was that the thermal syphon set up by this will carry dust particles in the atmosphere into clouds, nucleate and increase precipitation. The scientist concerned showed me statistical data that showed annual rain fall in the places where this was done was significantly more than if it was not done. The Met scientist did this wherever he was posted. Unfortunately this was never tried on a large scale.
    There is nothing wrong in the concept. All artificial rain making consists of creating nucleation sites for condensation. It is irrelevant how the nuclei are delivered into the clouds. However, there is no escape from the primary requirement of dark clouds being available for seeding.
    Sad that promising leads peter out for want of political will. If this was the case in 1957, no wonder nothing happens now.
  • IITBian 62yrs
    MemberJun 24, 2012
    Issue
    This I have already read on Google. But the expenditure is not so huge as $11million.
    It costs just maximum Rs.8000 for woodlogs and hard coal. No electricity required.
    It is transported to place where clouds gather but no rains.
  • Reya
    MemberJun 24, 2012
    Read an article on #-Link-Snipped-#. I think there are many ways involved in producing Artificial rain. Two ideas are explained very well in this article.
