Webmining or GridComputing ?
ms_cs
ms_cs
@ms-cs-Ab8svl Oct 23, 2024
Which is better webmining or grid computing to do a project, ? I am interested in both. But want to know which one has good value in software field.
    @thebigk Jul 11, 2009
    What kind of project are you planning to do in web mining or grid computing?
  • ms_cs
    ms_cs
    @ms-cs-Ab8svl Jul 11, 2009
    In webmining project, it keep track of history of web usage, ie particular website usage. So that it can help for better customer relationship.
    In grid computing, I want to do monitoring using my project in particular organization(example xyz organization).
    Both projects could be very useful and provide great learning. I see that with the web project you are more into 'Analytics' part; which is very good. It's difficult to answer which project will help you more in software field.
    I believe you should select the project which gives you more opportunity to show creativity and originality - which will be very much valued in software field.
  • ms_cs
    ms_cs
    The_Big_K
    Thanks for the suggestion Big_K. 😀
