    @thebigk Aug 2, 2018
    Could you tell us a bit more about your project so that we can provide you with well informed opinions?
  • Devika Ghosh
    @devika-FjmQCa Aug 2, 2018
    Banana and orange peels are used as adsorbents. It is used to treat the waste water. After adding the adsorbents it is said that there is a change in ph.
    Sounds like a good project idea to me. What makes you doubt that this can't be a final year project?
    @ramani-VR4O43 Aug 2, 2018
    There is one concern. Both peels are bioactive. If left in contact, they can rot, add bacteria (not necessarily pathogenic and harmful) and make the water smell.
    I did a bit of search. Various fruit peels can be chemically treated to increase their surface area, thereby making them adsorb harmful minerals.
    However, that will not render the water biologically safe for drinking.
    It can still be a project for recovering commercially viable metals from industrial waste water.
  • Devika Ghosh
    Both the peels are not used. Only one peel is used at a time. I have a doubt on whether it could be a final year project
    The point is that the peels are not used as such. They are chemically processed to get a structure like activated carbon.
    The processed material is used like activated carbon in a cartridge. Is there no guide for final year projects in the college to help students select a suitable one?
  • Devika Ghosh
    Yes sir but we have to find the topic on our own. Please give me some suggestions
    Are you familiar with such activation processes?
    Are you fixed on this orange peel  project? What sort of help you are looking for from CEans?
  • Devika Ghosh
    No sir. I have not fixed the topic. I came across this topic and thought that it can be my project.
    I am looking for environmental engineering projects mostly looking for water treatment process and air pollution related projects. Please help me with some suggestions
    @ramani-VR4O43 Aug 3, 2018
    Around 2010 a study done in Bangladesh showed that simple filtration of raw water through four layers of cotton saree consistently removed 99 % of cholera bacteria. This was confirmed by a follow up done after five years.
    <a href="https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2912662/" target="_blank" rel="nofollow noopener noreferrer">Simple Sari Cloth Filtration of Water Is Sustainable and Continues To Protect Villagers from Cholera in Matlab, Bangladesh - PMC</a>
    It maybe useful to try this out in India. There are labs in most cities that can evaluate the water for bacterial contamination. For the purposes of the project one can start with sterile water to which a known amount of a non pathogenic bacteria is added. This water is filtered through the selected cotton filter. The filtered water is analysed for the level of bacteria present. The filter is used a few times without checking for bacteria removal. After x cycles once more the bacteria level is checked. The filter cloth is washed and dried. Once again the test is repeated for bacteria removal.
    For repeatability at least two more filters are checked.
    A report can now be written.
    Please check with your guide if such a study is acceptable.
  • Manish Goyal
    @manish-r2Hoep Aug 3, 2018
    sir had already given you a very interesting point for your project
    You should do some research bit more about this
  • Devika Ghosh
    @devika-FjmQCa Aug 6, 2018
    Thank you sir
