  • Want to purchase Pyrometer and manometer for academic student experiment purposes
    Updated: Oct 22, 2024
    Views: 1.3K
    Can you help me to find out the seller and distributors to pyrometer(optical and radiation) and manometer like instruments for academic student experiment as well as purposes?
    Ananyaja Debadipta
    I am surprised that an engineering college purchase department does not have a database of approved suppliers.
    Unless more data on specs for the instruments are given, no one can give meaningful suggestions.
    What kind of manometer? What is the working fluid? What is the fluid whose pressure is monitored? What is the desired pressure range? Accuracy?
    It is best to make your own involving the students. It will be a good learning experience and lots cheaper.
    Optical pyrometers are expensive. Depending on specs price can be in lakhs.
  • Ananyaja Debadipta
    MemberSep 14, 2014
    A.V.Ramani
    Dear Sir,
    I will definitely involve the students and find out low cost specs to make students understand about the instruments. There are providers with institutes, these providers are usually taking much more than what the real cost is and these costs are also differing in thousands or lakhs depending on branded companies or PC Based Device. But the application and understanding is same. So I find all possibilities to find out or build low cost equipments for academic lab experiments or may be using simulators I will do something by which the student will get enough oppertunity to learn as well as they can start their own research.
    Thanking you.
