Voltage controlled resistor
mibawad
mibawad
@mibawad-hjwXTs Sep 28, 2024
Hello,
I would like to make a variable resistance controlled by voltage in order to get variable resistance for gain. I want the resistance change to be linear with the voltage. could you help me to find the circuit either by using transistor or by using op-amp.
  • chetan mehra
    chetan mehra
    @chetan-mehra-ZJKbfC Mar 7, 2011
    use MOStransistor for your purpose it is a voltage controllable device,,,if you are dealing with a sensitive project or equivalent......in its linear region it behaves as a voltage controllable resistor......
