Vista visual C++ incompatibility
sunit.soni
sunit.soni
@sunitsoni-iK2OBk Oct 25, 2024
hello friends ,
I have a labtop which is vista based . visual c++ is not compatible with it . Is this problem can be sort out..
  • yadavundertaker mohit
    @yadavundertaker-0p3HBs Nov 1, 2009
    Re: problem with vista
    you have to install borland software for C++ in vista.........visual C++ is not compatible to it.....
  • sunit.soni
    sunit.soni
    @sunitsoni-iK2OBk Nov 1, 2009
    yadavundertaker
    can i install xp over vista because visual c++ is compatible with xp.??
  • Mahesh Dahale
    Mahesh Dahale
    @mahesh-E2tZ3t Nov 1, 2009
    yap, Visual Studio C++ will run on Vista but will likely have a few compatibility issues
    1) As 32 bit vista does not support full screen 16 bit plarforms(like c/c++) and not at all suportable by 64 bit vista.
    2) One of the major problems was vista didn’t support the Full Screen mode.
    i don't know it will work or not but i found this on net try this
    install the display drivers of XP,
    that can be found at the site of the manufacturer of your Laptop/PC(in some cases graphics card manufacturer).
    mahesh_dahale
    you can't use the XP drivers in vista....drivers are operating sensible........
    sunit.soni
    ya you can install ...but first you have to install xp and then vista of you want to work on both....because on vista you can't boot xp as vista is higher operating version of window...........
  • Mahesh Dahale
    Mahesh Dahale
    sunit.soni
    mahesh_dahale
    don't you think there are too many steps .............and for a mechanzie they are out of reach....so follow the simple first install xp and then in other drive install the vista..........."make things simple" that's the motto of mechanical engineers.........
  • Mahesh Dahale
    Mahesh Dahale
    yadavundertaker
    ya it is easy to install xp first
    but he asked for that so i answer
    and about xp driver install
    mahesh_dahale
    i have DELL INSPIRON desktop which had vista installed from company.........i tried all the way but i was unable to run turbo C so i install xp and then vista.......and the drivers don't support the other operating system.. when you go to DELL site to download drivers you have to mention which operating system you are using to download them........
