  • komputergeek
    @komputergeek-Yf5hJ4 • Mar 22, 2009
    Try using attrib command..
    attrib * -s -h
  • sirijagan
    @sirijagan-WSPAL2 • Mar 23, 2009
    Try formatting it in command promt. format x: (where x is the drive alphabet.) before doing that, perform CHKDSK
  • just2rock
    @just2rock-DkmPtO • Mar 23, 2009
    pseudo,
    Do one thing ...use mcafee antivirus to treat the worm...else format in low level by restarting into safe mode using command prompt & then try to format same
  • Anil Jain
    @CrazyBoy • Mar 23, 2009
    pseudoI have got a worm in my pendrive which prevents deletion of any files in the pendrive. Cant format it either. Any help?
    Try to format this using Linux System.
    -Crazy
  • arunhero99
    @arunhero99-LRZv4M • Mar 23, 2009
    yeah....linux idea seems super 2 me also...
  • shakeeb_shuweb
    @shakeeb-shuweb-UvqmGA • Mar 23, 2009
    first of all backup the imortant data available in pendrive and install Mcafee Antivirus Enterprise edition which can be collected from friends circle if available. Format the pendrive either using WindowXP or Command prompt commands.
    If u want to prevent your dat getting affected from those harmful worms n viruses use compressed zip folder in pendrive to store data rather than usin normal folder. The compresses zip folders can be affected by viruses and the data stored in them will be secure n safe..........
    Good luck.....!!!
  • pseudo
    pseudo OP
    @pseudo-xFY6XA • Mar 24, 2009
    just2rockpseudo,
    what exactly do you mean by format in low level??
    @sirijagan
    tried formatting through dos but it gives the same error that comes while normal formatting 'disk is write protected'
    haven't tried linux yet. what is the command to format in linux?
  • Raviteja.g
    @ravitejag-02nJVr • Mar 24, 2009
    in linux no program can be executed with out commands.
    so, virus is nothing but a executable program with malicious output like formatting the remaining content in the pen drive, etc.
    so, u can open the pen drive and simply delete the file containing the virus.
    i think there is no format option in linux
  • Anil Jain
    @CrazyBoy • Mar 24, 2009
    Raviteja.gin linux no program can be executed with out commands.
    You are right buddy !!
    There is no such option named as format in Linux. You can simply open the pen drive and delete all the files containing virus in Linux Box.
  • pseudo
    pseudo OP
    @pseudo-xFY6XA • Mar 25, 2009
    Tried in linux. Getting the same error. files cannot be deleted as they are read only. ๐Ÿ˜•๐Ÿ˜•๐Ÿ˜•
  • Anil Jain
    @CrazyBoy • Mar 25, 2009
    pseudoTried in linux. Getting the same error. files cannot be deleted as they are read only. ๐Ÿ˜•๐Ÿ˜•๐Ÿ˜•
    In Linux we do have option to delete the files forcefully, if you are logging in using admin account.
    -Crazy
  • pseudo
    pseudo OP
    @pseudo-xFY6XA • Mar 26, 2009
    crazyboyIn Linux we do have option to delete the files forcefully, if you are logging in using admin account.
    -Crazy
    I tried deleting the files forcefully
    sudo rm -f filename ----> doesn't work
    Tried changing the file permissions
    chmod ugo+rwx filename
    and then deleting it
    rm -f filename ---> gives the same error.. Cannot remove file: read only file system
  • Raviteja.g
    @ravitejag-02nJVr • Mar 28, 2009
    pseudo,
    if you are using Ubuntu Linux then give a right click and change permissions of file access as "create and delete files" then save the permissions and then delete it any virus can be removed in Linux.
    hope it will work.
  • pseudo
    pseudo OP
    @pseudo-xFY6XA • Mar 29, 2009
    @Raviteja.g
    doesn't work. have tried almost everything now except breaking the pendrive ๐Ÿ˜‰. Is there any way to do it from the hardware?
