  • Morningdot Hablu
    @morningdot-6Xuj4M • Sep 24, 2010
    If your RAM memory goone full or when your RAM is in overflow condition it take some memory of HDD to store data that memory is called virtual memory.
    Again data's are swapped from HDD to RAM when you RAM found some spaces.
    So you can say that virtual memory is a temporary memory(Not permanent).
    You must find some files in temp file(in c drive) which is the residue lefted by the data while virtual memory take place.
  • anandkumarjha
    @anandkumarjha-jzdDMA • Sep 24, 2010
    @mohit:can we say that virtual memory is the part of main memory or not??????
  • Morningdot Hablu
    anandkumarjha@mohit:can we say that virtual memory is the part of main memory or not??????
    No anand virtual memory is not the part of the main memory.
    It's the part of HDD memory taken when your RAM is in overflow.
  • anandkumarjha
    @mohit: thanks brother for clearing my concept.till now i was considering it as the part of main memory
  • gauthamgingee
    @gauthamgingee-dJNP2g • Sep 29, 2010
    thanx mohit 4 ur answer
  • Sahithi Pallavi
    @sahithi-oJZaYj • Oct 2, 2010
    @mohit : nice!
    Is there any limit for virtual memory?
  • sushant005
    @sushant005-tyt4WK • Oct 2, 2010
    sahithi pallavi@mohit : nice!
    There is no limitation of Virtual Memory and it depends upon the size of hard disk.
    Operating System by default set the appropriate size of virtual memory but if we want more then we can change it but it does not make any sense because it unnecessarily takes some memory of HDD.
