@arunchary-VtqB3c • Feb 27, 2013
hi, use Lm7812 and use 1Amp fuse in following circuit
<a href="https://www.dropbox.com/s/st2svxj3urasspw/variable-power-supply-using-7805.PNG" target="_blank" rel="nofollow noopener noreferrer">Dropbox - variable-power-supply-using-7805.PNG - Simplify your life</a> -
Ibe OP
@ibe-sHoGz0 • Feb 27, 2013
is it okay if I will be using 220V AC? because it is the standard here in the philippines
yes, You can use this circuit because,in this circuit we have bridge configuration as follows in the circuit...............no issues....
Ibe OP
@ibe-sHoGz0 • Mar 3, 2013
aruncharyyes, You can use this circuit because,in this circuit we have bridge configuration as follows in the circuit...............no issues....
big thanks sir!
Ibe OP
okay, what diode should I use on the bridge rectifier?
@arunchary-VtqB3c • Mar 3, 2013
hi, you can use the diode 1n4007 or ready made bridge IC's are available like W10 so, you can replace with them also//...
