Vanadium Content in 4330V Steel
Sterlingz
@sterlingz-mlBZFj โ€ข Oct 26, 2024
Hi all,
Hope I'm posting this in the right forum! I have some questions with regards to 4330V steel. This is a Vanadium-modified 4330 steel, with Vanadium contents ranging from 0.05 - 0.15%.
I work for a company that builds tools for the mining industry, and our steel suppliers are divided on the issue of Vanadium content. Some say it should be near the 0.05% minimum, others say it should be at or near 0.15%.
The problem is that nobody here understands the impact of Vanadium in this steel and how (if at all) it affects its properties.
Any input?
    @ramani-VR4O43 • Nov 13, 2015
    SterlingzHi all, The problem is that nobody here understands the impact of Vanadium in this steel and how (if at all) it affects its properties. Any input?
  • Joseph Christie
    @joseph-christie-AvZA1I • Nov 18, 2015
    Sterligz
    According to you,"Some say it (V content) should be near the 0.05% minimum, others say it should be at or near 0.15%." and
    "The problem is that nobody here understands the impact of Vanadium in this steel and how (if at all ) it affects the properties of steel "
    I am not a metallurgist and most engineers and scientists rely on published data to settle a point like the one you have raised. Vanadium is a lot harder material than 4330 steel, and doping the latter with trace amounts of pure V imparts some of the hardness in modified steel. Either you buy these expensive manuals or publications that find out the facts or you do a hardness test in your engineering lab. But don't doubt the experience of others by wondering aloud if the addition of Vanadium in such low percentages (either at 0.05 % or at 0.15% ) really does something to the mechanical properties of steel . You may know that it is only this vanadized steel that is used in making hardest to break safes in banks etc.
    You can , here is US, buy test coupons or strips of the various alloys to do the mechanical testing.
    You may want to check out the info using the link below:
  • Joseph Christie
    added some info to previous message
