utilize the heat from the hot combusted gas coming out from aircraft engine
thirumalai99
@thirumalai99-liOvTi โ€ข Oct 8, 2024
is there is any idea to utilize the heat from the hot combusted gas coming out from aircraft engine
    @ramani-VR4O43 • Jul 24, 2012
    Any such system ha sto be light weight (as it will reduce pay load), aerodynamically designed (to minimise drag) and not introduce any backpressure ( to avoid reducing engine efficiency).
    Probably not worth the effort.
  • zaveri
    @zaveri-5TD6Sk • Jul 24, 2012
    bioramaniAny such system ha sto be light weight (as it will reduce pay load), aerodynamically designed (to minimise drag) and not introduce any backpressure ( to avoid reducing engine efficiency).
    which means that there wouldn't be much of waste gases coming out ?
    Not that. There is a lot of gas coming out. Lot of heat as well. However, recovery is not profitable at least as of now. Since the ambient is quite cold, probably a Peltier effect tail pipe can harvest some energy.
