Using solar power for mobile / transmission towers
vamsi kancharla
vamsi kancharla
@vamsi-kancharla-kL9oxU Oct 26, 2024
why dont we use solar energy for towers by fixing solar panels to towers and produce power for towers
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Oct 5, 2012
    The size of the solar needs to be large as the power generated in a single array is really smaller
  • vamsi kancharla
    vamsi kancharla
    @vamsi-kancharla-kL9oxU Oct 5, 2012
    output from solar panal is low but if we cover the tower with the pannels in a proper direction i think we can get sufficient output
    Ramani Aswath
    @ramani-VR4O43 Oct 5, 2012
    You get about 1 KWHr/ sq.mtr. over a full sunny day with a properly angled panel. This is too small for the intended purpose.
  • vamsi kancharla
    vamsi kancharla
    is there any solution, instead of useing solar pannels
  • vamsi kancharla
    vamsi kancharla
    Ramani Aswath
    Wind power could be an option. May not be legal in the location.
  • Jeffrey Arulraj
    Jeffrey Arulraj
    The only problem in the crowded cities are place of installation if that is available we can talk furthur in this topic
    Other wise we need to design a smaller version of the supply device
  • [Prototype]
    [Prototype]
    @prototype-G9Gn5k Oct 5, 2012
    vamsi kancharla
    You will just need an unfeasible amount of area for that. Towers consumes a lots of energy, yes to some extent you can try to provide some part of the power but driving completely with solar is not possible with the current technology we have.
  • vamsi kancharla
    vamsi kancharla
    @vamsi-kancharla-kL9oxU Oct 6, 2012
    but
    bioramani
    but it is not possible to install turbines in towns and cities
    Ramani Aswath
    @ramani-VR4O43 Oct 6, 2012
    vamsi kancharla
    but
    Up to 10 KW can be installed on house tops.
  • vamsi kancharla
    vamsi kancharla
    bioramani
    but we cannot get continuos wind flow to install on buildings
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Oct 6, 2012
    The wind flow will be continuous as lower power wind turbines need lesser wind speed for operation compared to the conventional wind mills in your mind
    Ramani Aswath
    vamsi kancharla
    Do you get 24 Hr a day sunlight?
  • vamsi kancharla
    vamsi kancharla
    bioramani
    no but cost of installing wind turbine is more and we cannot setup more turbines
  • vamsi kancharla
    vamsi kancharla
    no but cost for installing wind turbine is more and more over we cannot install more turbines right
  • Jeffrey Arulraj
    Jeffrey Arulraj
    vamsi kancharla
    Cost of solar panels is comparatively higher and so this is not feasible either
  • vamsi kancharla
    vamsi kancharla
    but the life will be more for solar pannels and less maintenence is enough
  • Jeffrey Arulraj
    Jeffrey Arulraj
    Both have several limitations which are to be considered more than to use them
    Ramani Aswath
    @ramani-VR4O43 Oct 7, 2012
    vamsi kancharla
    A 1 KW solar power pack costs about Rs. 200,000. Probably you can find out the power requirements of a cell phone tower and estimate the size (Solar collection area) and cost of a system to supply this power 24x7. At a guess you have to multiply the average power by five to get the peak power rating of the solar supply for this.
  • arunchary
    arunchary
    @arunchary-VtqB3c Oct 8, 2012
    yes, exactly i agree with bioramani sir,actually am working on solar home need products as R&D Eng, its quite different to go for solar and it also available in type of solar panels(pv cell configuration) small 3watt -6watt light is to required the battery ,solar panel etc it around 5000RS for total module coast.it am not saying not possible to install solar to CELLPHONE tower but it require AREA to install and RATING of usage... and also sun light considerations....
