@kedarjk-R7FdZW • Aug 28, 2008
Its a good thing, I don't think there is any disadvantage of using IMs.
So I think IMs should be allowed or rather encouraged to use IMs in offices. ๐ -
@gohm-F3UUpP • Aug 28, 2008
If the office is using IM for inter office communications then fine, otherwise they can prohibit usage as they see fit. Quite frankly with cell, e-mail and voicemail I'm busy enough with communications at work to need yet another form.
@prasad-aSUfhP • Aug 28, 2008
Usage IM in place of inter-office memos, and one liner mails is perfect. A lot of companies use this, in fact is a must for a virtual office setup. You can see the SameTime application in all the big firms, IBM, HP, Infosys, et al.
@Ash • Aug 28, 2008
Well.. the limit should be intranet IM. Even that, you'd might start chatting with a co worker friend at any time as you would during a lunch break.
So much for productivity ๐
If you want to encourage the use of IMs to have a synergy of information sharing for the sake of work, you'd have to educate the personnel on how to use it properly (and not abuse it).
