  • Use of automation for pump control
    parin bumia
    Member
    Updated: Oct 26, 2024
    Views: 1.0K
    actuaaly i have a 2 or 2.5 kw motor for rising the water to the tank at my floor..approx. 12 m height..now i want to have a contactor tht switches off the motor when the tank at my house gets filled....so..can anyone suggest me suitable IC and/or relay for tht purpose..
  • Jeffrey Arulraj
    MemberOct 28, 2012
    Use a simple water level detector that can be in any form
    I would suggest this an IR sensor and source to mark the maximum level of your tank the moment water crosses this level the amount of IR received by sensor will be less this can be used to activate a control relay to switch the power supply to your Motor thereby tripping it to off condition
  • parin bumia
    MemberOct 28, 2012
    ok...thnx....😀...and can u suggest a particular kind of control relay that will be capacble of withstanding high load current that taken up by motor?
  • grsalvi
    MemberOct 30, 2012
    Relays
    parin bumia
    Three Electro magnetic relays of appropriate rating in each phase shall do the work.
  • lal
    MemberOct 30, 2012
    Well I would suggest a simple float instead of the IR. I believe its much easier and less complicated compared to IR. The float will be rising with the water level and at right hight it makes contact thus actuating the relay.
  • Jeffrey Arulraj
    MemberOct 30, 2012
    #-Link-Snipped-# simple and exact nice suggestion friend
    I use this cable float switch:
    with this controller:
    I did the entire installation myself. No big deal. It is working without problem for years now.
  • parin bumia
    MemberOct 31, 2012
    thnx to all of u above for giving me suggestions...i will try to incorporate the feasible one.....thnx
