If the use 2-stroke engine in latest bike.is it possible?0
Administrator • Aug 8, 2012
I own a 2-stroke engine bike. So yes, it's possible.ganesh kalkutakiIf the use 2-stroke engine in latest bike.is it possible?Are you sure? This action cannot be undone. -
Member • Aug 8, 2012
thanku sir for the reply. But is it give better performance than 4-stroke engine?Are you sure? This action cannot be undone. -
What parameters are you including under 'performance'? I've always found the acceleration to be better than 4-stroke bikes I've tried. The mileage of course is lower.ganesh kalkutakithanku sir for the reply. But is it give better performance than 4-stroke engine?Are you sure? This action cannot be undone. -
Four stroke bikes have lower emissions. nowadays all bikes actually use four-stroke engines, only due to this reason.
are you owning a suzuki max 100r ? now thats a two-stroke bike as i know.Are you sure? This action cannot be undone. -
I own a Yamaha RX-Z, 5 Speed Model.zaveriFour stroke bikes have lower emissions. nowadays all bikes actually use four-stroke engines, only due to this reason.
I heard that 2-stroke engine develops more as compare to 4-stroke engine.as 2-stroke develops 1 power stroke for every crank rotation. and @big k sir for mileage which factors are involed.power is not consider to mileage?Are you sure? This action cannot be undone. -
Member • Aug 9, 2012
That is true. 4-stroke engine develops one power stroke for two rotations of crankshaft, whereas 2-stroke achieves it in only one rotation.ganesh kalkutakiI heard that 2-stroke engine develops more as compare to 4-stroke engine.as 2-stroke develops 1 power stroke for every crank rotation. and @big k sir for mileage which factors are involed.power is not consider to mileage?
power is not considered as mileage. mileage is the amount of fuel consumption for a given amount of work output. the more the fuel consumed, the lesser is the mileage.
power is nothing but the work that the engine can do.Are you sure? This action cannot be undone.
